Vacuum Hoses |
Vacuum Hoses |
zy84 |
Aug 16 2010, 10:19 AM
Newbie Group: Members Posts: 23 Joined: 12-February 10 From: Brownsville, TX. Member No.: 11,354 Region Association: None |
I have a question about the vacuum hoses. I searched previous threads and found some helpful stuff. I see there are kits available. My question: Is there anything special about these hoses? Are these something I can get at a local auto parts store by the foot or do I really need to find hoses made for the 914?
I tried clamping the ones I have but they are way to old and are basically crumbling. Thanks. Also what do you all think about moving the ignition coil to a different spot? |
windforfun |
Aug 16 2010, 10:26 AM
Senior Member Group: Members Posts: 1,801 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
The hose kits are handy. Everything is the right diameter & length. The routing diagram is helpful too. The hose isn't anything special. As far as the coil goes, keep it stock. There might be some RFI issues if you move it. Maybe not.
Cap'n Krusty |
Aug 16 2010, 11:07 AM
The biggest issue with locally sources is the fit. Most, if not all, of the hose carried by your FLAPS is gonna be in inch dimensions, what you need are metric sizes. The German stuff is better, too.
The Cap'n |
avidfanjpl |
Aug 16 2010, 01:20 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Totally agree on the kits and them being German in origin.
When I got my car, all the hoses were thrashed. Even the 4 large hose fittings to the FI Throttle Body. Made all the difference in the world. I bought the AA kit, then the fuel hose kit, then some more pieces, and even some fittings that were split. When they go bad, nothing works right. John |
zy84 |
Aug 16 2010, 03:51 PM
Thanks for the input
Lo-Fi Version | Time is now: 23rd May 2024 - 12:13 AM |
