| xsurfer |
Aug 20 2010, 11:34 AM
Member ![]() ![]() Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
How high does the car have to be to remove the stock six engine & trans?
Thanks Gene |
| PeeGreen 914 |
Aug 20 2010, 11:39 AM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
(IMG:style_emoticons/default/confused24.gif) What will it be set on? Are the carbs still on the car?
I lower the engine onto a furniture dolly and lift the rear about 2 - 3 ft. All slides out fine. (IMG:style_emoticons/default/beerchug.gif) |
| Jeffs9146 |
Aug 20 2010, 01:31 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have done mine many ways.
The first time I used a motorcycle jack and had to put the car about 3 1/2 feet up the next time I used a dolly and jack so it only took about 2 3/4 - 3 Feet. Now I have a dolly that is cut out in the middle so I can put the jack on the bottom of the engine and lower it onto the dolly both in and out. |
| IronHillRestorations |
Aug 20 2010, 07:36 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,920 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
If you take the intakes off you won't have to lift it as high.
| iamchappy |
Aug 20 2010, 07:38 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
34" for me.......I think........
| xsurfer |
Aug 20 2010, 09:40 PM
(IMG:style_emoticons/default/confused24.gif) What will it be set on? Are the carbs still on the car? I lower the engine onto a furniture dolly and lift the rear about 2 - 3 ft. All slides out fine. (IMG:style_emoticons/default/beerchug.gif) I was thinking w/o the carbs on, should save a lot of height. Back yard buddies makes a device that hold the car at about 26 inches off the ground. Thanks Gene |
Lo-Fi Version | Time is now: 7th March 2026 - 02:42 AM |
