EdArango |
914 Enthusiast ![]() ![]() Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California ![]() |
Hey Folks,
Is there someone out there that sells brand new wiring harnesses for a 1973 converting from 1.7 to 2.0 carbs?? If so, can you guys let me know who has them??? Thanks ED |
Ductech |
Member ![]() ![]() Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region ![]() |
Hey Folks, Is there someone out there that sells brand new wiring harnesses for a 1973 converting from 1.7 to 2.0 carbs?? If so, can you guys let me know who has them??? Thanks ED CLarify.... are you looking for the motor harness that would plug in to the relay board? or are you looking for a whole new harness for the chassis? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
CLarify.... are you looking for the motor harness that would plug in to the relay board? or are you looking for a whole new harness for the chassis? (IMG:style_emoticons/default/agree.gif) |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,972 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The chassis harness should be good for either carbs or FI. (IMG:style_emoticons/default/wink.gif) I am working on a new 914 chassis harness FWIW, should be available sooner than later, I have most of the complications worked out already.
As far as converting to carbs, you will still need your ignition harness and the stock harness design is good for carbs as is, unless you just happen to want or need a new one. If so, contact me, I have them. Here is the link to my harenss website: http://bowlsby.net/914/WiringHarnesses/ (IMG:style_emoticons/default/biggrin.gif) |
corsepervita |
Member ![]() ![]() Group: Members Posts: 327 Joined: 18-April 10 From: Redmond, OR Member No.: 11,631 Region Association: Pacific Northwest ![]() |
You can also reproduce them yourself too! If you have the patience (IMG:style_emoticons/default/beerchug.gif)
EdArango |
Hey Folks, Is there someone out there that sells brand new wiring harnesses for a 1973 converting from 1.7 to 2.0 carbs?? If so, can you guys let me know who has them??? Thanks ED CLarify.... are you looking for the motor harness that would plug in to the relay board? or are you looking for a whole new harness for the chassis? I just removed the engine and I would like to replace the whole wiring system that runs from the relay board though the firewall up along the tunnel to the gauges and ignition. I'm not 100% sure what exactly I need or want to replace, I just want to know if there available out there. Thanks ED |
EdArango |
The chassis harness should be good for either carbs or FI. (IMG:style_emoticons/default/wink.gif) I am working on a new 914 chassis harness FWIW, should be available sooner than later, I have most of the complications worked out already. As far as converting to carbs, you will still need your ignition harness and the stock harness design is good for carbs as is, unless you just happen to want or need a new one. If so, contact me, I have them. Here is the link to my harenss website: http://bowlsby.net/914/WiringHarnesses/ (IMG:style_emoticons/default/biggrin.gif) It appears as you are the person to get my wiring issues resolved. Thanks Jeff the info. ED |
zx-niner |
Member ![]() ![]() Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California ![]() |
Jeff made me one for my carb conversion. The replacement wiring is pretty simple and it really cleans up the engine bay. Price is right, too, for something brand new and custom made.
You will still need to figure out how to power up the fuel pump on your own, however. |
avidfanjpl |
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region ![]() |
Everyone loves Jeff's work. It is good enough for me. I just ordered a correct harness for my 2.0L 73 DJet FI, even with the correct new boots.
Worth saving for. Mine will be in this weekend. His work in pictures and soon in my hands is flawless. I have had the nasty stuff, and this is a middle-aged man's dream come true, and it doesn't need lobster and pearls. John |
JeffBowlsby |
John...you are way too kind...your harness shipped today, here it is. Check out them boots baby....
(IMG:style_emoticons/default/yikes.gif) Attached image(s) ![]() |
SirAndy |
You will still need to figure out how to power up the fuel pump on your own, however. http://www.914world.com/bbs2/index.php?showtopic=25954 (IMG:style_emoticons/default/shades.gif) Andy |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,585 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
The chassis harness should be good for either carbs or FI. (IMG:style_emoticons/default/wink.gif) I am working on a new 914 chassis harness FWIW, should be available sooner than later, I have most of the complications worked out already. Excellent, it'd probably be easier to work out the right front wiring issues on my car with a new harness...PO did a real hack-job when replacing the front fender (wires don't operate the correct stuff and grounds suck!). Can't wait to see the new products when they come out! |
avidfanjpl |
Got it today, Jeff! Artwork indeed!
Maybe will get it installed this weekend! THANKS! J |
Lo-Fi Version | Time is now: 9th July 2025 - 04:53 PM |
