> V8 conversion, Question about firewall
kevin311
post Aug 26 2010, 06:26 PM
Oh the wonders of POs...
I got the car for free so its not that bad, but this car was definitely loved for a long time before the people before me had it. So far i have found no significant rust but some of the redneckery on this car is just hilarious. Pics will tell some of the story..
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1282868813.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1282868816.2.jpg)
I think they got tired of welding half way through, and thought "screw it we'll rivet the top"
Anyway with the firewall being hacked to all hell and planning on doing a v8 conversion do i need to relocate the water pump or just cut out whats already "gone" and weld a box around it?
I know its long winded but, thanks for your input.
Kevin
Replies(1 - 13)
rick 918-S
post Aug 26 2010, 06:54 PM
Hey nice rack! -Celette
(IMG:style_emoticons/default/welcome.png) Buy a used firewall and replace it. Check Renegade for the parts you need to relocate the water pump.
Andyrew
post Aug 26 2010, 07:08 PM
Spooling.... Please wait
The stock water pump comes through the firewall about 4 inches... I would relocate the pump and replace the firewall unless you are short.
jimkelly
post Aug 26 2010, 07:38 PM
Delaware USA
not only does using a stock water pump put the water pump in the passenger cabin - it makes installing the engine more tricky.
Andyrew
post Aug 26 2010, 07:41 PM
2 inches...
Wow that is one recessed water pump setup! Never seen one that close to the block
Mike Bellis
Resident Electrician
Renegand Hybrids will have all the parts you need. V8's are fun!!! Andrew's is so much fun, he's scared to drive it (IMG:style_emoticons/default/poke.gif)
Fire wall looks like a true custom job. Maybe they ran out of welding wire??? If you weld in the stock piece, the engine will fit by moving the tranny back 1.25 inches and using the remote water pump. (IMG:style_emoticons/default/aktion035.gif)
Andyrew
post Aug 26 2010, 07:49 PM
Its because I have more power than you
(IMG:style_emoticons/default/finger.gif)
On a more serious note. If you use tall valve covers the drivers side recess for the seat needs to be bumped in about an inch. Something to consider when your welding in the new firewall.
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-172-1282873752.1.jpg)
Note the left valve cover and how close it is to the firewall. That is pushed back about an inch and a half.
Andyrew
Better pic.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1094107806.jpg)
Mike Bellis
post Aug 26 2010, 07:53 PM
QUOTE(Andyrew @ Aug 26 2010, 06:49 PM) *
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif)
kevin311
post Aug 26 2010, 07:57 PM
Hey Jim what kind of pulley setup is that?
I'm not necessarily trying to cut corners or anything just reviewing some options since the car is already hacked.
I can see how a stock water pump would sit by looking at Jim's pic but that setup is definitely doable.
Thanks
Kevin
kevin311
post Aug 26 2010, 08:04 PM
Wow! Quick replies!
Thanks for all the info, you guys ROCK! (IMG:style_emoticons/default/aktion035.gif)
i couldn't finish typing my last ? before there were like 3 more replies!
Thanks again
Kevin
computers4kids
post Aug 26 2010, 09:16 PM
Love these little cars!
Renegade waterpump setup.
(IMG:http://www.914world.com/bbs2/uploads/post-4253-1252300281_thumb.jpg)
jimkelly
post Aug 27 2010, 05:39 AM
Delaware USA
my pulley - i can not remember where i bought it - maybe jegs.
http://www.jegs.com/webapp/wcs/stores/serv...65899&Nty=0
maybe spectra 4369 ??
my pump was given to me froma friend who called it a sbc short pump.
note that whate ever engine bar you get, you will need the corresponding trans mounts - as they measurements go hand in hand. my buddy made both for my car - so dims are slightly different than that of renegade's stuff.
i would go all renegade if i were to do it again.
this ebay item looks like my pulley set - 400087851353
jim
QUOTE(kevin311 @ Aug 26 2010, 06:57 PM) *
Thanks
Kevin
andys
post Aug 27 2010, 09:50 AM
I moved my firewall out 1" and added an access panel; actually two access panels. One for the serpentine drive, and the other for the thermostat housing and its hose. If it looks a bit odd, thats because mine is an LS1 swap as opposed to the more traditional SBC swap. I retained the stock water pump and reconfigured the serpentine drive to fit the 914 firewall. BTW, the 914 backpad still fits and has a bit of a somewhat un-noticeable gap that I will fill with some sort of vinyl covered spacer.
Andys
- Lo-Fi Version Time is now: 31st July 2025 - 10:41 PM
