Handbrake question, how to make it work good |
thomasotten |
Aug 29 2010, 03:08 PM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Question about my handbrake. It works, barely, enough for inspection, so that is not the issue. My issue is that on the passenger side, when you pull the handbrake, it stops the wheel OK, but when you release, I see the lever on the caliper goes back, but not 100%. So the caliper is still grabing the disk. I think it is either two things: 1. the brake cable itself has too much grab, or 2. the spring on the caliper has worn out. Or what else? (IMG:style_emoticons/default/confused24.gif) Should I just throw out the old cables? |
Drums66 |
Aug 29 2010, 03:19 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....try lube on the cable's & caliper's 1st (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif)
maybe things are frozen?? |
Eric_Shea |
Aug 29 2010, 06:08 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
The spring will not give out... It could be the cable and, they're a fairly inexpensive fix @ $33.00 from most of the good guys.
On many occasion the "Wiper Seal" on that handbrake arm is rusted to the arm and body. It's just a rubber wiper seal but, if water gets in there the seal can rust binding the arm. This happens often on 914 calipers as many have used an agressive solvent to clean the calipers. Because of the seals location, the solvent can sit in there and expand the seal. Once it expands, it can bind the arm itself or, it can let water in and the rusty seal to metal combo can make it stick. One way to tell if this is it would be to remove the cable from the caliper and move the arm back and forth without the cable attached. Use a thick glove and it should be fairly easy to do by hand. If the arm sticks in one place... you have a caliper issue. To make your handbrake work better "overall" make sure your venting clearance is adjusted properly. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:16 AM |
