Question about my handbrake. It works, barely, enough for inspection, so that is not the issue. My issue is that on the passenger side, when you pull the handbrake, it stops the wheel OK, but when you release, I see the lever on the caliper goes back, but not 100%. So the caliper is still grabing the disk. I think it is either two things: 1. the brake cable itself has too much grab, or 2. the spring on the caliper has worn out. Or what else?
Should I just throw out the old cables?
