> Original washer system (spare tire)--who uses it still?
bembry
post Aug 30 2010, 01:47 PM
Does anyone still have their original 914/4 windshield washer system working?
Did anyone "resurrect" theirs from disrepair? If so, how difficult was it to fix?
Do these work worth a damn when they do work?
Replies(1 - 18)
dr914@autoatlanta.com
post Aug 30 2010, 01:51 PM
They work great and the usual failure is the tubing. Typical to wet ones lap when they fail.. Tubing is readily available as are the rest of the parts one may need. Just inflate the tire to 36 lbs The system will stop working when the tire pressure reaches around 29
QUOTE(bembry @ Aug 30 2010, 12:47 PM) *
tradisrad
post Aug 30 2010, 02:02 PM
I've never had a working one, but my current car may be easy to get to get going!
underthetire
post Aug 30 2010, 02:08 PM
I know all my pieces are still in there, but with the 5 lug inflatable kinda useless for me.
Spoke
post Aug 30 2010, 02:14 PM
Jerry
Yep, mine works just fine. I only need it one time each year when I get the car inspected. I usually just put a little water in it and don't connect it to the spare.
windforfun
post Aug 30 2010, 02:19 PM
QUOTE(tradisrad @ Aug 30 2010, 01:02 PM) *
Ditto. Ditto.
(IMG:style_emoticons/default/sunglasses.gif) (IMG:style_emoticons/default/sunglasses.gif)
tradisrad
post Aug 30 2010, 02:27 PM
QUOTE(windforfun @ Aug 30 2010, 01:19 PM) *
Ditto. Ditto.
Wind,
Where in San Mateo do you live? I am in the Highlands.
-Rob
windforfun
post Aug 30 2010, 03:06 PM
QUOTE(tradisrad @ Aug 30 2010, 01:27 PM) *
Ditto. Ditto.
Wind,
-Rob
Up top on Hillsdale Blvd.
Drums66
post Aug 30 2010, 03:38 PM
914 Rudiments
(IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/poke.gif)
(group buy anyone!)
Krieger
post Aug 30 2010, 06:15 PM
Is there anyone out there that sands down their windshields with the wipers/squirters when the windshield is that dirty? Maybe I just don't need them in sunny Cali, but I know that glass is pricy.
davep
post Aug 30 2010, 06:17 PM
914 Historian
I developed a holder for a switch to replace the valve. That way you could use a pump, and eliminate a fluid line from coming into the cabin.
Tom_T
post Aug 30 2010, 06:46 PM
TMI....
QUOTE(dr914@autoatlanta.com @ Aug 30 2010, 12:51 PM) *
Brent - it is the K.I.S.S. system to perfection, plus it gives you a "warning signal" to check the spare pressure & inflate when they don't work! (IMG:style_emoticons/default/biggrin.gif)
The hoses can break with either the spare air pressure or 914-6's electric motor driven pressure - as well as the plastic water bottle can crack over time (same with any car), but check & sop-up/dry-out any leakage completely to avoid future rust problems in the sheet metal etc.
I'd recco putting in all new hoses - including to the steering column at the wiper stalk switch & maybe the T-fitting & cowl jets/valves too on the cowl (chrome type for 73 still available PP, AA, Peli, SMG, etc.), then pressure test the bottle & all the fittings. You may have to save & re-use the connectors at the tire valve stem, bottle & the joiner at the F-trunk bulkhead, cuz IIRC they are NLA - but the hoses can be changed. Also, I've only seen the clear hose, but mine is the black, but don't know if black is still available.
Word of warning - I figured out that's what happened with mine to rust out the lower pan at the pass. steering cross-member strut attachment point - right under where the water bottle sits, & I had a cracked bottle replaced at one point.
Good Luck getting it going again! (IMG:style_emoticons/default/beerchug.gif)
Pat Garvey
post Aug 30 2010, 07:16 PM
Do I or don't I...........?
I just tested mine (with distilled water), and it still works just fine. No leaks, no damp laps.
But....I will replace to 38 year old tubing, just in case.
Pat
whatabout1
post Aug 30 2010, 07:29 PM
Toys in Red
What spare ? Ya mean that old tire and rim with only 4 bolts holes ? It was in
the way of the oil cooler venting. Not running LeMans, don't need it.
Pat Garvey
post Aug 30 2010, 07:39 PM
QUOTE(whatabout1 @ Aug 30 2010, 07:29 PM) *
Trust me...yes you will!
nsr-jamie
post Aug 31 2010, 06:52 AM
914 guy in Japan
I finally got my working after 15 years of having no windshield washer...I had to change the switch and than all the hoses...than I kept blowing off hoses at the switch and had water pouring out from under the dash...I fixed it with some racing safety wire from some of my motorcycles and that seems to work well, while you are at it check your (check) valves in the line, don't pull out any hoses till you have the new ones strongly attached and be very careful, its not that big of a job if you do it right the first time....my system actually works quite nice now and I need it for the bi-annual inspections here in Japan. Cheers
underthetire
post Aug 31 2010, 09:52 AM
QUOTE(davep @ Aug 30 2010, 05:17 PM) *
I like that piece. I was thinking the same thing IF i ever get around to doing the conversion. Got prints? or do you sell the piece? looks like you did it on a 3D printer, I have access to one...
davep
post Aug 31 2010, 02:10 PM
914 Historian
QUOTE(underthetire @ Aug 31 2010, 07:52 AM) *
Yes, I can sell a kit.
BarberDave
post Aug 31 2010, 03:30 PM
Barberdave
In 2000 when I bought my 914 ,windshield washer didn't work. Will I thought I
would fix that. I put fluid in the bottle air in the spare and vola it worked. The
next day it didn't. Checked no air presure in spare, took it to the tire shop, leaked
all around the bead. They took in apart and dumped at least a Gal. of fix a flat
out of it. Cleaned the rim real good ,put the tire back on vola it held air. That
was the first of the crappy repairs the previous ( POS owner ) did.
All part of the 914 mistique. Dave
- Lo-Fi Version Time is now: 12th June 2026 - 08:00 AM
