| 2Lyelo914 |
Sep 1 2010, 03:27 PM
Newbie ![]() Group: Members Posts: 18 Joined: 22-July 04 From: Naperville, IL Member No.: 2,384 |
Any procedure on putting this in a '74, 914 2.0L?
Thanks. Jim |
| underthetire |
Sep 1 2010, 03:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Soak the old one in PB blaster for days before you try and remove it.
| avidfanjpl |
Sep 1 2010, 06:12 PM
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
A lot of us took a long 13mm socket and dremeled out a channel so the wire can avoid getting squashed.
I have removed and installed 3 lately, so I removed the injector connectors from the injectors, took off the injector pipes completely, then had all the room I needed to remove the rubber grommet and install the CHTS with nothing in the way. I then put the stuff back, and it took 10 minutes. Even in 100 degree heat. I also removed the deceleration valve and the MPS first. Makes for easy access. John |
| Gint |
Sep 1 2010, 08:20 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,108 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Moving to the garage...
| Jeffs9146 |
Sep 1 2010, 08:32 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE A lot of us took a long 13mm socket and dremeled out a channel so the wire can avoid getting squashed. I ground a notch in an extension to fit the wire through then you can save your 13mm! |
| McMark |
Sep 2 2010, 01:12 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Are we talking fuel inject CHT? Or aftermarket dash gauge CHT?
| malaga_red75 |
Sep 2 2010, 02:02 PM
'74 2.5L N/A Subie ![]() ![]() Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
QUOTE A lot of us took a long 13mm socket and dremeled out a channel so the wire can avoid getting squashed. I ground a notch in an extension to fit the wire through then you can save your 13mm! I did this too, about half-way up a long-sleeve 13mm just cut out a notch and slipped the wire through. -peter |
| majkos |
Sep 2 2010, 03:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Lo-Fi Version | Time is now: 10th June 2026 - 03:33 AM |
