> does the brain have a memory?, basic d-jet question
bradtho
post Sep 1 2010, 07:09 PM
I set my timing again this last weekend. If forgot to pull the vacuum hoses at first. it was running pretty rough afterwards and I couldn't figure out what was wrong. Anyway, after I pulled the hoses and reset I took it for a drive and it was still missing and had a weird induction noise. It was late so I went to bed and vowed to try again tomorrow. when I took it for a spin in the morning all was well.
so, what happened? the only thing I can figure for why it was running bad that first night is that the djet brain was still trying to compensate for my failed attempt to adjust the timing. If that's the case, how do you convince the brain to reset? or is something else going on?
Replies(1 - 12)
seebobgo
post Sep 1 2010, 07:58 PM
Open the pod bay door's HAL (IMG:style_emoticons/default/popcorn[1].gif)
ConeDodger
post Sep 1 2010, 08:08 PM
Apex killer!
Old analog technology. It doesn't remember anything.
jeffdon
post Sep 1 2010, 08:26 PM
QUOTE(seebobgo @ Sep 1 2010, 06:58 PM) *
Dave? Dave?
bradtho
post Sep 1 2010, 09:22 PM
QUOTE(ConeDodger @ Sep 1 2010, 07:08 PM) *
that's what I would have thought, but I can't come up with any other reason why 12 hours of sitting makes it drive so differently.
ConeDodger
post Sep 1 2010, 09:39 PM
Apex killer!
QUOTE(bradtho @ Sep 1 2010, 07:22 PM) *
These cars can act very differently warm to cold...
Bleyseng
post Sep 2 2010, 03:36 AM
Aircooled Baby!
especially if you knocked a vacuum hose off and didn't see it.. (IMG:style_emoticons/default/hissyfit.gif)
Mark Henry
post Sep 2 2010, 05:22 AM
that's what I do!
QUOTE(Bleyseng @ Sep 2 2010, 05:36 AM) *
You didn't do something right, forgot to hook it up, knocked it off, etc.
Also check the points, sometimes when you gap them they spring in with too little gap.
type47
post Sep 2 2010, 06:15 AM
Viermeister
It healed overnight (IMG:style_emoticons/default/biggrin.gif)
pilothyer
post Sep 2 2010, 07:36 AM
After you gave up the night before did you mention the problem to your Higher Power ? (IMG:style_emoticons/default/hands.gif)
realred914
post Sep 2 2010, 08:03 AM
Group: Retired Members
my brain remembered me shorting out an injector wire once, it never worked again! (burnt the power transistor out) so yes they do have a sort of memory, but not like what you is thinking of.
underthetire
post Sep 2 2010, 11:58 AM
Seems I am quickly becoming the same (IMG:style_emoticons/default/biggrin.gif)
Just a bunch of comparison circuits with a few drivers really. Temp makes a big difference, so does fuel pressure. I would check the fuel pressure next time it acts up.
windforfun
post Sep 2 2010, 01:57 PM
QUOTE(jeffdon @ Sep 1 2010, 07:26 PM) *
Dave? Dave?
- Lo-Fi Version Time is now: 10th June 2026 - 03:48 AM
