> Valve adjustments, Can it be done without removing the exhaust?
914rat
post Sep 2 2010, 03:40 PM
I have been removing the exhaust is there an easier way?
Replies(1 - 17)
VaccaRabite
post Sep 2 2010, 03:41 PM
En Garde!
QUOTE(914rat @ Sep 2 2010, 04:40 PM) *
You bet. Just do it without removing the exhaust!
No really, you don't need to remove the exhaust to do this job. Its more tricky, but your hands do find a way, and it takes much less time.
Zach
brant
post Sep 2 2010, 03:42 PM
4cylinder or 6?
I never remove the exhaust on 4cylinders.
brant
windforfun
post Sep 2 2010, 03:45 PM
QUOTE(brant @ Sep 2 2010, 02:42 PM) *
4cylinder or 6?
brant
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
jeffdon
post Sep 2 2010, 03:48 PM
QUOTE(914rat @ Sep 2 2010, 02:40 PM) *
Nope. I dreaded the first "in car" valve adjust, but if you get her up high enough on some good jackstands, and wiggle around a lot, you will figure it out.
I find the way I am laying makes a big dif. A lot of the time, i am laying diagonally under the car, with my head practically under the trailing arm so that I can see things.
It takes time, but its nothing to be feared.
914rat
I'll try it but it sure is tight in there.BTW its a 2056 4cyl.I have a lift so getting it up in the air is no problem.
underthetire
post Sep 2 2010, 03:55 PM
Super easy. But then again I have a header system (IMG:style_emoticons/default/biggrin.gif)
jeffdon
QUOTE(914rat @ Sep 2 2010, 02:48 PM) *
Thats what I have. You do a lot of the work with one hand reaching from the front, and one from the rear.
Oh, I do remove the J-tubes from the heating system for access.
ELLIOTT
post Sep 2 2010, 03:56 PM
yes , its tight
post Sep 2 2010, 05:48 PM
Tighter than socks on a rooster but it gets easier every time.
Cap'n Krusty
post Sep 2 2010, 06:23 PM
Cap'n Krusty
Never crossed my mind. I've always done them with the exhaust system in place, both 4 and 6 cylinder versions. The big problem with pulling the HEs is fastener failure/disaster, and that's something you REALLY don't want to deal with.
The Cap'n
Steve
post Sep 2 2010, 06:30 PM
Have you ever done it with factory six heat exchangers? According to the manuals you have to remove the right heat exchanger. Sorry about the hijack. Just curious.
Cap'n Krusty
post Sep 2 2010, 06:53 PM
Cap'n Krusty
Yes.
The Cap'n
914rat
post Sep 3 2010, 11:14 AM
QUOTE(Cap'n Krusty @ Sep 2 2010, 04:23 PM) *
The Cap'n
I would agree but I renew the hardware if it's the least bit funky and I've become quite proficient in taking the HE's and related stuff down.It does make it easier for valve adjustments and cleaning up underneath the car but it seems to be getting anal and I don't want to break an exhaust stud.Gonna try it with the HE's in place.
VaccaRabite
post Sep 3 2010, 11:34 AM
En Garde!
You will hate it the first time. the third time it will be no big deal.
I'd be worried each time I dropped the exhaust about a stud breaking.
Zach
914rat
post Sep 3 2010, 12:10 PM
Just saying that jinxed somebody somewhere I'm sure.I try not to wake the 914 demons by saying things like that. (IMG:style_emoticons/default/happy11.gif)
simonr
post Sep 3 2010, 02:07 PM
The hardest part for me was getting the bales off and then back on. It was recommended to use a shop rag to pull them down . Man o man did that make it easier.
windforfun
post Sep 3 2010, 03:43 PM
QUOTE(Vacca Rabite @ Sep 3 2010, 10:34 AM) *
Zach
Excellent advice.
- Lo-Fi Version Time is now: 10th June 2026 - 03:49 AM
