4 point with harness bar, show me your installs |
qa1142 |
Sep 6 2010, 08:22 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
what are you using and how did you install
Did you keep you backpad? I would like to... What brand 4 point are you running? How did you anchor the shoulder belts? Got pictures? Ideally, I would like to get in, buckle, sinch and go (IMG:style_emoticons/default/driving.gif) |
Mike Bellis |
Sep 6 2010, 07:29 PM
Go with a cam lock harness. This will be the easyest to use and look better than the old hook type. Simpson and Sparco make good ones.
Most harness bars bolt to the existing pillar seat belt bolt. This puts the bar slightly into the rear window view. I have an extra Weltmeister harness bar. $115 to your door, free shipping. PM me if you want it. |
Elliot Cannon |
Sep 6 2010, 10:11 PM
Ideally, you should use a 5 point harness. The crotch belt keeps the lap belt low on your lap instead of rising up to your stomach and rib cage. The shoulder harness shouldn't be mounted and lower than a 5 degree angle below your shoulders to prevent spinal damage.
Cheers, Elliot PS You should take up Mikes offer and buy his harness bar. |
DanT |
Sep 6 2010, 10:30 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
If Will is not on board with the harness bar....drop me a PM....I am interested in it...Have just started looking for one. (IMG:style_emoticons/default/biggrin.gif)
McMark |
Sep 7 2010, 01:50 AM
Perfect timing on this topic. I was just talking about this today and wondering what brand of belts people were using + pros & cons
'73-914kid |
Sep 7 2010, 07:02 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I have Crow latch and link 5 point harnesses in my car, and really like them. They're incredibly easy and foolproof to unlatch in a hurry, unlike cam locks, which I tend to fumble with.
Crow also has better prices generally than the other bigger name brands.. |
qa1142 |
Sep 7 2010, 07:21 AM
I have harness bar, looking for the input on harnesses now
how about pictures of Crow and camlock now (IMG:style_emoticons/default/poke.gif) |
jetboy |
Sep 7 2010, 07:41 PM
914 Uber Noob Group: Members Posts: 205 Joined: 16-September 05 From: Riverside, CA Member No.: 4,810 Region Association: Southern California |
I hope you have a roll cage installed. 4/5 point harness in a rollover means your going to end up a LOT shorter when your head is supporting that weight.
DanT |
Sep 7 2010, 07:50 PM
not necessarily.....
have you seen a 914 at a track event on it's lid? the targa bar does not fail, and does not deform....it is the windshield header that is the weak link. And if you have the top in place even the windshield header does not deform that much. If anything, you need a reverse roll bar that runs across the windshield header or you need a cage... (IMG:style_emoticons/default/smile.gif) |
Vysoc |
Sep 7 2010, 09:11 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
I have the Schroth 4 Pt Harness (Ralley Model). I do not have a harness bar but they make the 4 pt Ralley specifically for harness bar applications. I got it from the BMW aftermarket people up in Mass. The belts have the ASM System (Anti Sub Marine). I worked for awhile to get mine to fit the 10% maximum below the shoulder. I also mounted them through a plate on the other side of the engine wall for strength. I can provide pictures but not from home....sorry. I know......This Thread Is Worthless Without Pictures!!!! Sorry, We are in the middle of a move and I have to move! I like the Scroth product very high quality. Vysoc (IMG:style_emoticons/default/sunglasses.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 01:57 PM |
