| glens67 |
Sep 8 2010, 07:14 PM
Newbie ![]() Group: Members Posts: 35 Joined: 13-March 10 From: Middleton, ID Member No.: 11,462 Region Association: Rocky Mountains |
Well after my first oil change on my 73 1.7 I over filled the crank case by about 1/4 quart of Chevron delo 400 30W. Every thing was fine after a short run around the neighborhood. The next day I went for a longer drive and made a hard left sweeper. The next thing I saw was the biggest blue cloud of oil smoke out the tail pipe. I thought that I had blown the engine. Pulled over and checked the gages, no oil light and the 1.7 was idling fine. Took of again no smoke ran great.
BUT... The 914 will pour blue smoke on any kind of hard left turn. Seem to do it a lot less if I keep the oil level at about 1/2 qt. down. I'm thinking that the exhaust guides maybe a little loose on the right head. Any suggestions?? Thanks Glen |
| Mike Bellis |
Sep 8 2010, 09:43 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Sounds like a valve guide to me but I'm no expert.
| Elliot Cannon |
Sep 8 2010, 09:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Check your valve cover gaskets.
| TheCabinetmaker |
Sep 9 2010, 06:37 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Distributor seal needs replaceing. .
| Tom_T |
Sep 10 2010, 02:45 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
914s & VWs aren't real keen on being overfilled, & you can damage an aircooled engine by overfilling.
It will generally burn off seeking the path of least resistance, so check per the others' comments above. Also watch your future refills closely & don't go over! |
| Drums66 |
Sep 10 2010, 03:01 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 9th June 2026 - 02:25 AM |
