Webcam Camshaft Help |
tornik550 |
Sep 9 2010, 07:57 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I decided to pull my engine to fix a few things. The PO rebuilt the engine with a Webcam Camshaft. Since I pulled my engine, I decided to pop off the oil pump and see what the code is on the camshaft for future reference. I found the numbers but I cannot figure out the grind- lift/duration... information on webcams website. Can anyone help me locate this info. Here is what was stamped on the end of the camshaft-
WEBCAM 5-90 98 108 LC I also couldn't find any support email address for webcam. Thanks in advance, Steve |
carr914 |
Sep 9 2010, 08:06 PM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
tornik550 |
Sep 9 2010, 08:17 PM
carr914 |
Sep 9 2010, 08:50 PM
Call them in the afternoon. They open at 9am Pacific Time
Jake Raby |
Sep 9 2010, 08:56 PM
Those are all casting numbers.. the grind number is on the drive flange adjacent to the oil pump drive. If you get this number I can give you the specs.
tornik550 |
Sep 9 2010, 09:22 PM
(IMG:style_emoticons/default/laugh.gif) I went outside to recheck the numbers. I was reading the 98 up-side-down- it is actually 86.
So my next question- does this GENERALLY sound like a reasonable setup for street and a little autox (I hope it is because it is what i've got- I do realize that my carbs are a bit small but that is what I have) 78.5mm crank 96mm p/c 2.0l heads webcam 86 cam (lift 0.423, duration 270) weber 40 idf (34mm vents) |
Lo-Fi Version | Time is now: 31st May 2024 - 11:25 PM |
