Daytime running lights, How do I rewire the switch? |
Markl |
Sep 11 2010, 06:25 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
Hey all, I know I've seen this, but can't find the thread(s). I want to use my foglights as daytime running lights (not as flashers). There's a way to rewire the switch so the fogs will come on w/o the headlights, right? Anyone know the procedure?
Thanks! |
swl |
Sep 11 2010, 06:37 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
I haven't done it but it should be really straight forward. The fogs are driven through a relay so power draw is not an issue. Just wire pin 87 of the relay to a fuse that is hot only with the key on. Like the radio.
Depending on what it looks like on the panel it might be easier to take the red/black off Fuse 10 and move it over to the radio fuse. Then leave the fox switch on all the time. |
dlee6204 |
Sep 11 2010, 06:47 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I just did this on my car tonight. It took 15 minutes at most!
http://members.rennlist.com/demick/fogrewire.html |
Markl |
Sep 11 2010, 07:25 PM
Yeah, that's the one - thanks!
dr914@autoatlanta.com |
Sep 11 2010, 08:35 PM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Yes it is easy by moving a wire on the headlight switch and one on the fuse block. One turns on the lights when the headlights are on the other only on low beam. There is a complete explanation in the 914 book "Tech Tips 700" by dr 914
Hey all, I know I've seen this, but can't find the thread(s). I want to use my foglights as daytime running lights (not as flashers). There's a way to rewire the switch so the fogs will come on w/o the headlights, right? Anyone know the procedure? Thanks! |
underthetire |
Sep 11 2010, 08:50 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
FWIW the Jwest kit does that, gives you flash to pass, and GREAT instructions.
Lo-Fi Version | Time is now: 5th June 2024 - 07:26 PM |
