Where does this wire go?, Mystery wire... |
PBR |
Sep 12 2010, 06:40 PM
Newbie Group: Members Posts: 7 Joined: 4-October 09 From: Boston Member No.: 10,885 Region Association: None |
Hi Guys,
Can someone tell me where this wire is supposed to be connected to? It is white and splits off from the insulation of the wire that goes to the distributor. (IMG:http://www.914world.com/bbs2/uploads_offsite/img205.imageshack.us-10885-1284338444.1.jpg) Splits off from the insulation for this wire (IMG:http://www.914world.com/bbs2/uploads_offsite/img208.imageshack.us-10885-1284338444.2.jpg) It's a '74 2.0 Thanks! |
dr914@autoatlanta.com |
Sep 12 2010, 06:45 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The white wire in the ignition harness near the distributor goes to the auxiliary air valve. It has a red wire coming out of the bottom of it.
PBR |
Sep 12 2010, 06:51 PM
The white wire in the ignition harness near the distributor goes to the auxiliary air valve. It has a red wire coming out of the bottom of it. Great, thanks for the quick reply! Now... what does the auxiliary air valve do exactly? And where would it be located~ I'm guessing around the intake (?) ***EDIT*** NVM, I found the answer. My 914 is missing that valve though. Is it essential for smooth running though? The car currently will start sometimes... but not every time. Still trying to figure out why that is. |
Cupomeat |
Sep 12 2010, 10:03 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Auxiliary air valve is intended to help the car on cold start.
It allows additional air to raise the idle of the car until the heating element heats up and closes the valve, thus giving you warm idle air from the bypass around the throttle body. Lacking a AAV would make a tougher idle at cold temps, but little else in normal running. |
PBR |
Sep 12 2010, 10:16 PM
Good to know, thanks for the info. Hopefully I'll be able to find the real issue soon.
Lo-Fi Version | Time is now: 7th June 2024 - 10:40 PM |
