| mgphoto |
Sep 15 2010, 01:42 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,431 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I just wanted to share a project that I had been planning for the last 20 years, a 5 lug changeover.
I had been gathering the parts for a long time and I finally said I was gonna do it, I set the time aside (planned on it taking 7 days but small problems came up and a total of 11 days) and here is the result. ![]() |
| pcar916 |
Sep 15 2010, 01:50 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
Lookin' good!!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif)
| mgphoto |
Sep 15 2010, 01:52 PM
The project kicked off with a rebuild of my transmission, the box came back just as the 5 lug project started, I wanted to add anti-sway bars and as many 914/6 suspension parts that I could find.
![]() ![]() I also decided to add a few safety items, Tangerine Racing's 9.5mm to 8mm fuel line adapter and their Master Cylinder Brace. |
| Sleepin |
Sep 15 2010, 02:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Very nice!!!!
| type47 |
Sep 16 2010, 06:11 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
What stub axels did you use?
| qa1142 |
Sep 16 2010, 06:40 AM
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Very nice (IMG:style_emoticons/default/shades.gif)
Only took me 6 years to decide on this upgrade. Parts are at Redi-strip, calipers are with Eric, should all be home within 2 weeks (IMG:style_emoticons/default/wub.gif) I am going with solid rear rotors, like your vented, don't think I need them for a 4 Drive hard my firend (IMG:style_emoticons/default/driving.gif) |
| Eric_Shea |
Sep 16 2010, 07:15 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Looks awesome Mike.
Hows the first drive impression with the sway bars? I remember that being the only thing I added to my -6. All 914's should have come with them... Manditory. |
| mgphoto |
Sep 16 2010, 10:01 AM
What stub axels did you use? Hey type47, The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue. Mike |
| mgphoto |
Sep 16 2010, 12:17 PM
Looks awesome Mike. Hows the first drive impression with the sway bars? I remember that being the only thing I added to my -6. All 914's should have come with them... Manditory. Hello Eric, First off, thanks, without your help I would never have gotten this off the ground. As for the anti-sway bars, I can tell you that the car seems to want to take the turns before I even think about steering input! I have not taken any really fast corners yet as I need to fix an exhaust leak and bleed the brakes again. Mike |
| Eric_Shea |
Sep 16 2010, 03:56 PM
Gone but not forgotten is that "I'm piloting a Chris*Craft" feeling! LOL
| oldschool |
Sep 16 2010, 05:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,374 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
What stub axels did you use? Hey type47, The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue. Mike what do you do in the media world? (IMG:style_emoticons/default/shades.gif) |
| mgphoto |
Sep 16 2010, 05:13 PM
bump
| mgphoto |
Sep 16 2010, 05:14 PM
bump
| mgphoto |
Sep 16 2010, 05:16 PM
What stub axels did you use? Hey type47, The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue. Mike what do you do in the media world? (IMG:style_emoticons/default/shades.gif) reconstituted photojournalist, I am now a Hollywood Celebrity event photographer, I own a website called Superstarimages.com also videographer for the Hollywood Chamber of Commerce for the world famous Hollywood Walk of Fame. |
| oldschool |
Sep 16 2010, 05:39 PM
What stub axels did you use? Hey type47, The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue. Mike what do you do in the media world? (IMG:style_emoticons/default/shades.gif) reconstituted photojournalist, I am now a Hollywood Celebrity event photographer, I own a website called Superstarimages.com also videographer for the Hollywood Chamber of Commerce for the world famous Hollywood Walk of Fame. Very cool, I'm in the local 600,If you need any help let me know. |
| mgphoto |
Oct 24 2010, 01:05 AM
A bit more than a month now and I needed to remove the drivers side front strut to tighten the ring holding the cartridge in the strut, (might have forgotten to tighten it down on assembly.)
I readjusted the front wheel bearing, used the Motive Power Bleeder to bleed the brakes, also cracked the fittings on the brake pressure regulator to bleed it, now the pedal is really firm. The car handles GREAT! Glad I did it, anti sway bars and all.... Only one regret, I didn't install cross drilled rotors, I need to bring the weight down. |
Lo-Fi Version | Time is now: 14th April 2026 - 11:36 PM |
