Fuel Pump Clacking Noise, Do all pumps sound like this? |
7TPorsh |
Sep 17 2010, 04:57 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I haven't been around other 914s in person so not sure if this is normal.
I have a dual weber 2.0 with a Facet fuel pump located under the battery tray on the block/tin.. When i turn the ignition on, i get a really loud clicking and cackling noise coming out off the engine compartment, i am guessing it's the pump. My old fiat's pump used to whine a little and sounded cool like a cam gear driven engine. This pump makes a racket and makes the running engine sound even louder. Is the noise the pump? Do facet pumps do this? Is there another electric pump i can install that will be quiet or will make a more pleasing tone? |
dr914@autoatlanta.com |
Sep 17 2010, 05:03 PM
914 Guru Group: Members Posts: 7,888 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes especially when the tank is dry or the flow restricted. You may want to rubber mount the facet with the 914 style fuel pump mounts AND not have it mounted higher than the carbs.
I haven't been around other 914s in person so not sure if this is normal. I have a dual weber 2.0 with a Facet fuel pump located under the battery tray on the block/tin.. When i turn the ignition on, i get a really loud clicking and cackling noise coming out off the engine compartment, i am guessing it's the pump. My old fiat's pump used to whine a little and sounded cool like a cam gear driven engine. This pump makes a racket and makes the running engine sound even louder. Is the noise the pump? Do facet pumps do this? Is there another electric pump i can install that will be quiet or will make a more pleasing tone? |
Lo-Fi Version | Time is now: 4th June 2024 - 09:16 AM |
