Space saver spare, moving to 5 lug |
qa1142 |
Sep 19 2010, 05:26 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Show me your space savers
How did you mount yours if you run front cooler? Where did you get yours? Pelican? Will it matter if I am running 16X6 (front) and 16X7 (rear) |
jt914-6 |
Sep 19 2010, 06:16 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Mounted my space saver spare in rear trunk as front was taken up with oil cooler and fuel cell. Got it from a friend's shop who works on Porsches. I think it's from a 944. It is a 165/15.....I'm using 7 & 8 X 15's
qa1142 |
Sep 19 2010, 06:31 PM
Targa top still fits on top of that?
jt914-6 |
Sep 19 2010, 06:41 PM
JRust |
Sep 19 2010, 08:47 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I had a 16x7 fuch with a 205/55 that I put in my rear trunk. It fit with the top no problem. I have a space saver now but the original fit fine.
PRS914-6 |
Sep 19 2010, 11:19 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I don't know what brakes you are using but the 964 spare was the only one to clear my brake setup on 16" wheels. Check clearance before the final install
Andyrew |
Sep 19 2010, 11:47 PM
I use a full size tire in my trunk. Targa fits over it just fine!
205 50 15 IIRC |
Elliot Cannon |
Sep 20 2010, 01:12 AM
Call Jonathan at GPR. I think I saw a few spares in his shop last Saturday.
Attached thumbnail(s) |
qa1142 |
Sep 20 2010, 06:41 AM
I don't know what brakes you are using but the 964 spare was the only one to clear my brake setup on 16" wheels. Check clearance before the final install Stock '74 911T but this is what I think I want and how did you mount that without punching a hole in the gas tank? |
PRS914-6 |
Sep 20 2010, 08:59 AM
Stock '74 911T but this is what I think I want and how did you mount that without punching a hole in the gas tank? I did it with the gas tank out. I used a plate about 4 inches square and drilled a small hole in each corner. Drilled a 1/2" hole in the center, slid a long bolt through and welded the bolt head to the plate. Next I set the spare in the car and drilled a 1/2 inch hole through the center of the wheel through the firewall. I slid the bolt/plate in from the gas tank side and used pop rivets to attach the plate to the firewall. I use the OEM 964 jack that's in molded foam inside the wheel and there is still enough room above it to store tools inside the wheel. The whole setup works pretty well and leaves the trunks with a little more room for gear. |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:56 AM |
