can anyone help me identify this bent tube, accelerator cable and speedometer tubes |
JayDubbya |
Sep 20 2010, 12:55 PM
Newbie Group: Members Posts: 14 Joined: 27-July 10 From: Chicago Area Member No.: 11,985 Region Association: None |
I am in the process of replacing the accelerator cable and the speedometer cable. But I have run into a conundrum: There is a third tube visible from beneath the car. And I cannot identify that tube. And it is very similar in appearance to the accelerator cable tube. And it is badly bent and has a cable sticking out of it that appears very similar to the trailing end (the end which attaches near the throttle body) of an accelerator cable. The cable is firmly stuck inside the bent tube and so far I have not been able to pull it free to see more of it.
If anyone can refer to the attached image file and tell me what the bent tube is for I'd really appreciate it. (Note - the blue-colored line in the photo might cause confusion. That blue line is what I was using to "fish" the new accelerator cable through the tube.) |
yeahmag |
Sep 20 2010, 12:59 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Heater flaps. Connects to the red leaver by the shifter. Should be another one like it too.
Cupomeat |
Sep 20 2010, 01:21 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Heater flaps. Connects to the red leaver by the shifter. Should be another one like it too. Yes, there is, you can see it in the picture above the shift rod bellows. BTW, 75-76 heater cables are shorter than earlier years. BUT they only sell one size anymore, the longer ones. |
JayDubbya |
Sep 20 2010, 07:33 PM
Hey AARON & ERIC-
Thanks for the fast and excellent feedback! You probably guessed my greatest fear - that maybe the previous guy had threaded the accelerator cable through the wrong hole because the correct one was all bent up. There are so many things I've encountered that are done backwards or horribly wrong on this car that I fear taking for granted that most anything is routed or wired correctly. After reading your remarks that there was a second heater tube, I got under the car again and sure enough there is a second bent tube which is bent in the opposite direction - toward the driver's side of the car. Thanks again ! -JW |
rick 918-S |
Sep 20 2010, 07:54 PM
Hey nice rack! -Celette Group: Members Posts: 20,478 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Lo-Fi Version | Time is now: 4th June 2024 - 07:34 PM |
