Newb Lug Bolt Q's |
Newb Lug Bolt Q's |
Cambo |
Sep 22 2010, 01:12 PM
Member Group: Members Posts: 122 Joined: 21-April 10 From: California Member No.: 11,641 Region Association: Northern California |
Got some used lug bolts cheap on Craigslist. Just want to make sure they are for the 2.0 fuchs. Ball seat looks correct from pictures I've seen. They are about 1 3/4 inches long with about one inch of thread. Sound correct? Just want to make sure these aren't too short. Thanks
Jerry75914 |
Sep 22 2010, 01:20 PM
Member Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
"one inch of thread" sounds like you have the shorter 25mm bolts...NOT what you want. I had those when I got the car, and they did not thread very deeply into the rotors...scary.
You need the 38mm bolts. if you are in the Bay Area, go to Parts Heaven in Hayward. They have some reproductions that are well priced. |
Cambo |
Sep 22 2010, 01:26 PM
"one inch of thread" sounds like you have the shorter 25mm bolts...NOT what you want. I had those when I got the car, and they did not thread very deeply into the rotors...scary. You need the 38mm bolts. if you are in the Bay Area, go to Parts Heaven in Hayward. They have some reproductions that are well priced. So when you say 38mm, that's 38mm of thread length? These bolts do have about 25mm thread length. |
DanT |
Sep 22 2010, 01:28 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
38mm of thread is the correct length for factory alloys.
Jerry75914 |
Sep 22 2010, 01:30 PM
yes, I'm referring to thread length.
I had them on the fronts with 2.0 Fuchs, stripped the thread halfway into the rotor...threads deeper in looked brand new... |
Cambo |
Sep 22 2010, 01:38 PM
Thanks guys, lesson learned. They were advertised as 2.0 lug bolts on CL. At least it only cost me $20 to learn the hard way. (IMG:style_emoticons/default/headbang.gif)
Drums66 |
Sep 22 2010, 04:33 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
38mm of thread is the correct length for factory alloys. that's it (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/yellowsleep[1].gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/bye1.gif) P.S. don't score the cheap 1's |
DanT |
Sep 22 2010, 09:10 PM
like this (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:36 AM |
