SOT: Cleaning an electrical switch?, No P-car content, but old car content. |
KaptKaos |
Sep 22 2010, 04:11 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I have an old Volvo that I need to replace the turn signal switch on the column. I have the new (used) switch, but I want to make sure it's clean before I install it. It has some gunk in there. Here it is:
What's the best way to clean this up to ensure good connections and operation? I had heard of people using CLR on bits like this, but I assume that it will take a while to dry if I do that? Others have said WD40, but I am not sure about that. Any sort of contact cleaner or something I should be looking for? Let me know. TIA |
KaptKaos |
Sep 22 2010, 09:03 PM
Bueller, Bueller, anyone, anyone?
Mike Bellis |
Sep 22 2010, 09:07 PM
Radio shack or Fry's.
Buy contact cleaner and a tooth brush. after cleaning use TV contact lube. |
KaptKaos |
Sep 22 2010, 09:23 PM
Thanks Mike.
So nothing that immerses the part, right? |
hot_shoe914 |
Sep 22 2010, 09:30 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
I will have to check to see what kind it was, but contact cleaner on my relay board and all plug ins, relays and pins just fixed my '73 2.0.
cary |
Sep 23 2010, 07:13 AM
CRC ......... in the black, red & white spray can. I get mine at NAPA.
Can't quite tell in the picture. But use a pencil eraser on any of the copper contacts you can get at without harming the switch. |
underthetire |
Sep 23 2010, 08:50 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Just make sure if it has plastic in it to get plastic safe contact cleaner. OHHH I have stories about that... Also, soaking in Coca Cola works well to (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 3rd June 2024 - 05:14 AM |
