wheel camber, how to correct rear wheel camber |
chrispy |
Sep 22 2010, 07:50 PM
Newbie Group: Members Posts: 48 Joined: 5-May 09 From: modesto, ca Member No.: 10,337 Region Association: None |
My 1972 914 is mostly alive and back on the road (subject to DMV approval).
I purchased this non-op car and noticed excesive wear on the 10 year old tires, but planned on replacing them any way. Now that its off the jacks and rolling, I noticed the rear wheels having an inward lean of say 7 degrees on both sides. I thought it might be short springs so I changed them with some spare stuts from my parts car. No change. I've searched on-line for tech articles on adjustment but so far zero. Any ideas Thanks chrispy |
trapper |
Sep 22 2010, 07:56 PM
Newbie Group: Members Posts: 37 Joined: 6-February 03 From: Brighton, MI Member No.: 258 |
My 1972 914 is mostly alive and back on the road (subject to DMV approval). I purchased this non-op car and noticed excesive wear on the 10 year old tires, but planned on replacing them any way. Now that its off the jacks and rolling, I noticed the rear wheels having an inward lean of say 7 degrees on both sides. I thought it might be short springs so I changed them with some spare stuts from my parts car. No change. I've searched on-line for tech articles on adjustment but so far zero. Any ideas Thanks chrispy Rear camber on a 914 is set by adding or removing shims. Shims are removed to increase negative camber so it sounds like you don't have any shims installed. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:29 AM |
