Shift linkage boot (cover), loose |
ripper911 |
Sep 25 2010, 01:41 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I walked out to the parking lot a few minutes ago, and noticed something on the bottom of my car. (IMG:style_emoticons/default/dry.gif)
So, I look, and it is the cover that goes over the connection for the shift rod at the transmission end. The strap is still in place, but I know the end of it has been bent a little bit trying to get it on and off again and again doing my clutch recently. Any other good ways to hold that thingy on? I'm working all weekend, so i'll be in a work van for a couple of days. I might just pull it off before going home, or try to slip it back on and hope it holds, or duct tape... (IMG:style_emoticons/default/givemebeer.gif) |
type47 |
Sep 25 2010, 03:09 PM
Go to your local hardware store and get a stainless steel "hose" clamp like the ones that have a little worm gear drive to tighten them up. If you can't find one long enough, get 2 and put them together. Here, those type of clamps are in the plumbing section around vent hoses, rubber hoses and such...
bandjoey |
Sep 25 2010, 05:37 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Yep. I got 3 really large -like4"- hose clamps and put them together. It snugs up really tight.
rfuerst911sc |
Sep 25 2010, 05:54 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Home Depot and Lowes have large screw clamps so you can get this done with one just need to get the right size.
ripper911 |
Sep 26 2010, 07:15 AM
Thanks everybody, I'll try that!
(IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/girlboing.gif) (IMG:style_emoticons/default/prop.gif) (IMG:style_emoticons/default/clown2.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 12:18 PM |
