Carb questions |
Carb questions |
matteyp |
Oct 7 2010, 08:45 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
Does anyone know if the single barrel weber carb manifiold used on the 1.7s would fit on the 2.0
kphimself |
Oct 7 2010, 08:52 PM
Member Group: Members Posts: 124 Joined: 6-September 10 From: VA Beach, VA /Fayetteville, NC Member No.: 12,146 Region Association: MidAtlantic Region |
r_towle |
Oct 7 2010, 09:09 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
bolt patterns are different, but a drill can fix that.
Port size and shape does vary a bit, you can port match it if you care. Should fit, with some effort. Rich |
kphimself |
Oct 7 2010, 09:14 PM
Did they change that pattern on them at some point? Mine bolted right up, unless the guy i bought them off or had a 1.7 and thought it was a 2.0. I feel bad, sorry if i gave you some bad info.
r_towle |
Oct 7 2010, 09:20 PM
2.0 is a three bolt intake. (Wider position of the outer ear studs)
1.8 and 1.7 is a four bolt intake (two in the middle, outer ears are about 1/8 inch closer) Some manifolds have three bolt holes in the middle and they have oval holes on the outer ears so they fit on anything... Rich |
jaxdream |
Oct 8 2010, 08:29 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Was the single barrel weber a 34ICT ??? Smaller carb , shorter intake length stack.Check to see if it clears enough , a 34ICT on a 1.7 is minimal as it is , on a 2.0 l it wouldn't be quite enough , general / popular thought.
Jack / Jaxdream |
Lo-Fi Version | Time is now: 7th June 2024 - 11:27 AM |
