Question about the E-brake wire, how did it go ?? |
jsayre914 |
Oct 13 2010, 04:11 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Now that i am piecing the interior back togeather, i find myself asking those small detailed questions....
the e brake wire comes out from the tunnel near the firewall and i think it goes across the floor into a hole w/ grommet right next to the brake switch located in the crossbar under the drivers seat. Did that wire just run across the floor?? I forgot to snap a pic thanks |
SirAndy |
Oct 13 2010, 04:35 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Did that wire just run across the floor?? Nope. It's tucked away behind the backpad and the carpet on the long. (IMG:style_emoticons/default/popcorn[1].gif) |
jsayre914 |
Oct 13 2010, 04:51 PM
Thanks andy
(IMG:style_emoticons/default/beerchug.gif) |
zymurgist |
Oct 13 2010, 06:29 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
So it goes into a harness in the tunnel, then? I've been puzzling over this on Babydoll for a long long time now...
McMark |
Oct 13 2010, 06:38 PM
The e-brake switch wire branches off from the main body harness at the rear of the cabin, near the firewall. It then runs along the firewall between the backpad and the sound pad (although the floor works fine) then along the floor towards the cross member. It enters the cross member on the back side through a small round grommet. When you're hooking up the switch you'll want to pull the wire out of the square hole in the top of the cross member, attach it to the switch, then screw the switch into place. There is only a single wire. The wire is a ground wire, and when the ebrake is up the switch grounds the wire to illuminate the warning light. When the ebrake is down, the connection is broken, and the light goes out.
Eric_Shea |
Oct 13 2010, 08:48 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
you sure about that... (IMG:style_emoticons/default/huh.gif)
(IMG:style_emoticons/default/biggrin.gif) Man... I've got a pile of wire I want to delete. Come on over Mark. |
McMark |
Oct 13 2010, 10:45 PM
(IMG:style_emoticons/default/biggrin.gif) Sounds like fun!
Lo-Fi Version | Time is now: 2nd June 2024 - 10:16 AM |
