Accelerator cable, sticking or tight acclerator cable-causes? |
DRPHIL914 |
Oct 14 2010, 12:27 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Accelerator has always seemed tight, like it takes 2x the foot pressure than it should.
Throttle body does not seem sticky, but could it be a really stiff spring, or is the cable just tight/gunked up? it is a 75 2.0 and i have had it for 1 year, no idea if it has ever been replaced. another thing, though, If engine is warm, been running for several hours, and i go to stop, clutch and let off accelerator cable, it is slow to decelerate. I do not see this just much just drving to work in the morning(20 min). How hard is it to run a new accelerator cable? Phil |
pete000 |
Oct 14 2010, 12:33 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I have this same issue with my newly acquired 74.
I think it is in the linkage behind the pedal that is connected to the pedal cluster. The engine side it seems free and not bound up. I have to take the floor board out and check pivot of the linkage. I picked up a new cable and accelerator pedal, they are fairly inexpensive. Let us know what you find out. (IMG:style_emoticons/default/beerchug.gif) |
VaccaRabite |
Oct 14 2010, 12:38 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
possible issues:
* Throttle cable wrapped around the clutch cable * Throttle cable wrapped around the brake fluid line * Throttle cable frayig and getting ready to break * Return spring on the throttle cable is too tight Zach |
Als914 |
Oct 14 2010, 12:44 PM
Lighting my way Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
Accelerator has always seemed tight, like it takes 2x the foot pressure than it should. Throttle body does not seem sticky, but could it be a really stiff spring, or is the cable just tight/gunked up? it is a 75 2.0 and i have had it for 1 year, no idea if it has ever been replaced. another thing, though, If engine is warm, been running for several hours, and i go to stop, clutch and let off accelerator cable, it is slow to decelerate. I do not see this just much just drving to work in the morning(20 min). How hard is it to run a new accelerator cable? Phil Hey Phil, It could be hung up some where in the tunnel (IMG:style_emoticons/default/hissyfit.gif) . If I only owned the car a year I would probably be inclined to change the throttle, clutch and speedo cables. I have had oustanding results (IMG:style_emoticons/default/first.gif) with Teri cables for the clutch and throttle as I have had these in my daily driver for more than ten years. I will be replacing all my cables this month,this way I know the age of all my cables. The cost is apporx. $110 thru Pelican. |
SUNAB914 |
Oct 14 2010, 12:53 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Phil, PM sent.
Drums66 |
Oct 15 2010, 03:34 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
...Maybe ancient throttle body?? (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) |
914itis |
Oct 15 2010, 06:54 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Accelerator has always seemed tight, like it takes 2x the foot pressure than it should. Throttle body does not seem sticky, but could it be a really stiff spring, or is the cable just tight/gunked up? it is a 75 2.0 and i have had it for 1 year, no idea if it has ever been replaced. another thing, though, If engine is warm, been running for several hours, and i go to stop, clutch and let off accelerator cable, it is slow to decelerate. I do not see this just much just drving to work in the morning(20 min). How hard is it to run a new accelerator cable? Phil they are not hard to replace at all, 10 minutes average. I just did mine yesterday. first you have to unhook from the pedal , then the carb. Jack up the car, you will see the tunel, just pull it out. push the new one into the tunel and attach back on both ends. I would also check the spring on the carbs to make sure that they are not putting to much pressure on the pedal. |
76-914 |
Oct 15 2010, 07:08 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
One other place that a 75 can stick. Look at the small cut out on the air box for the end of the lever on the throttle body shaft. It's only about an 1/8" cut out and hard to see. How do I know???? (IMG:style_emoticons/default/confused24.gif)
tracks914 |
Oct 16 2010, 04:52 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
When I did my last restoration, I gutted the car. When I went to pull out the throttle cable, it jammed. The nylon sleeve was so old that it broke apart and jammed the cable somewhere in the tube. BTW you cannot push a cable back in a tube. I tried!!!!!!!!!
I ended up breaking the cable inside the tube. It ended up that the jam occurred between the shifter and the firewall. In the end I had to cut out a 6 inch section of the tunnel and a 6 inch section of the throttle cable tube (IMG:style_emoticons/default/sawzall-smiley.gif) and splicing in a new piece. (IMG:style_emoticons/default/welder.gif) NOT FUN!!! Now my new cable is a bit tight like yours but I don't want to mess with it. (IMG:style_emoticons/default/blink.gif) Good thing all this happened during a restoration and not after the car was completed. |
96740 |
Oct 18 2010, 12:38 PM
Member Group: Members Posts: 327 Joined: 10-March 08 From: Thousand Oaks, CA Member No.: 8,791 Region Association: Southern California |
This thread is perfect timing. I'm going to be replacing my accelerator and clutch cables. Was going to order the Terry Cables from pelican. I've heard a few people say that the TC's accelerator cable is more flexible. How are the Terry Cables?
DRPHIL914 |
Oct 18 2010, 01:08 PM
Ok. Well, i spent some time looking at each end on this. The throttle body i think is o.k., and i do not think the return spring is the problem. when accelerated at the throttle body by hand it pops right back. I actually think it is the pedal itself causing the problem, or the front linkage that pulls the cable when the pedal is pressed upon. I had checked the clearance at the airbox- it is close but not the problem. But just because it is 35 years old, i am going to do the following;
A: replace the cable- new one on the way; B: since i have a rebuilt clutch/brake pedals from SUNAB914-chris, and i have a new pedal board from the Group Buy(aluminum) that i was going to put in, i will pull the old board, replace the pedals, lube or replace the linkage for the accelerator, put the new cable in and see what happens. I think Als914 has good suggestion, my speedometer cable is bad, too, so going to do both at same time. Will let you all know how it goes, but hey, any one have advice on shift linkage bushing replacement- another separate issue right now? anyway, should be done next week. Phil |
SUNAB914 |
Oct 18 2010, 01:20 PM
Speedo cable is a little more fun. be prepared. Center console and center cushion, carpet have to come out. Good luck.
patssle |
Oct 18 2010, 01:55 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Ok, might be a newbie question - how the heck do you get to your accelerator cable? My floor was covered in bed liner, so maybe there are some hidden panels I'm not seeing (besides the 1 covering the electrical wires, and the square panel near the firewall). But other than those, I can't get into the central tunnel to see where my sticky accelerator is happening.
bandjoey |
Oct 18 2010, 05:05 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Bad or missing Transmission ground strap can cause the cable to become a ground and will fry the cable someday, welding it to the tunnel. A possibility to check out.
Gint |
Oct 18 2010, 06:24 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Here's another possible cause. The cable or the casing wears on the inside of the tube. You can't tell when moving the cable by hand. But under tension as it is when installed it's rough. BTDT. All other things remained the same, replaced the cable with a new stock replacement and cured the problem. Cables are cheap enough, and if it turns out not to be the cable, you now have a spare. Which is never a bad idea.
Lo-Fi Version | Time is now: 10th June 2024 - 07:39 AM |
