Need Rear Sway Bar mount bushing |
nein14 |
Oct 18 2010, 10:21 AM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
anyone have any new rear weltmeister sway bar mount bushings? can't find anyone that sells them
dr914@autoatlanta.com |
Oct 18 2010, 10:59 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
realred914 |
Oct 18 2010, 11:03 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
got a fat front sway bar and no rear bar, friend had simular set up in his car but he also had a rear bar. after driving both cars, he was convinced to remove rear bar, he never went back to it, handled better without. may not be the case with yoru car, bpends on the oever all set up you have. we spoke to someone that races these 914 a bit, and he also had teh same obserrvation, the rear bar may not be an improvement. some folks do still like them, maybe depends on how the other things on car are set up?
mine was lowered, 150 lbs rear springs, front bar, 195 50 tires good luck |
nein14 |
Oct 18 2010, 02:43 PM
got a fat front sway bar and no rear bar, friend had simular set up in his car but he also had a rear bar. after driving both cars, he was convinced to remove rear bar, he never went back to it, handled better without. may not be the case with yoru car, bpends on the oever all set up you have. we spoke to someone that races these 914 a bit, and he also had teh same obserrvation, the rear bar may not be an improvement. some folks do still like them, maybe depends on how the other things on car are set up? mine was lowered, 150 lbs rear springs, front bar, 195 50 tires good luck thanks ! I have a GT clone have driven it with and without the rear sway bar I fell it handle better with the car has been lowered and corner weighted (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 04:38 PM |
