914 shifter |
airhead ![]() ![]() Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States ![]() |
i had my wheels balanced and they had to put a lot of weights on them.are rivieras known for this? (IMG:style_emoticons/default/lol-2.gif)
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
i had my wheels balanced and they had to put a lot of weights on them.are rivieras known for this? (IMG:style_emoticons/default/lol-2.gif) Nope - at least not with my original Rivs - the later repops may be different, or you may have a bent/tweaked rim, or the tires may the problem. FYI - the "real" Rivs look like this with the smooth outer rim (and interlocking lower case "r" logo on the center caps), whereas the repops have the lip to attach clip-on weights (not advised in any case & they look tacky). ![]() ![]() (IMG:style_emoticons/default/popcorn[1].gif) |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
Not speaking from experience , from what I've read on the forum about wheels , the later repops some times take a lot of weights. You might contact Chris Foley - Tangerine Racing , he makes a set of centering rings for 914 hubs which center the wheels a lot better than the lugs do , some guys have used these with good success , YMMV...Good luck...
Jack / Jaxdream |
914 shifter |
Not speaking from experience , from what I've read on the forum about wheels , the later repops some times take a lot of weights. You might contact Chris Foley - Tangerine Racing , he makes a set of centering rings for 914 hubs which center the wheels a lot better than the lugs do , some guys have used these with good success , YMMV...Good luck... Jack / Jaxdream thank you for the info Jack |
RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,255 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
Not speaking from experience , from what I've read on the forum about wheels , the later repops some times take a lot of weights. You might contact Chris Foley - Tangerine Racing , he makes a set of centering rings for 914 hubs which center the wheels a lot better than the lugs do , some guys have used these with good success , YMMV...Good luck... Jack / Jaxdream thank you for the info Jack If they say DOT anywhere on them, they are not 'real' Rivieras..... ask me how I know. |
kphimself |
Member ![]() ![]() Group: Members Posts: 124 Joined: 6-September 10 From: VA Beach, VA /Fayetteville, NC Member No.: 12,146 Region Association: MidAtlantic Region ![]() |
I had the same issue with mine and the new tire didn't hold air at all. I had my brother take it to work and take it off and it was full of crude that the shop didn't clean off, old fix a flat and mystery goo. After the wheel was cleaned and the tire reinstalled it was almost perfect. That was an original i do have a repo as a spear and i noticed it has alot of defects from the casting. I intend to use it as a spear.
kphimself |
A fake rim.
Attached image(s) ![]() |
914 shifter |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I had the same issue with mine and the new tire didn't hold air at all. I had my brother take it to work and take it off and it was full of crude that the shop didn't clean off, old fix a flat and mystery goo. After the wheel was cleaned and the tire reinstalled it was almost perfect. That was an original i do have a repo as a spear and i noticed it has alot of defects from the casting. I intend to use it as a spear. Most spears I've seen are long and pointy stick thingies. They don't look anything like a Rivvie wheel ............................. The Cap'n |
kphimself |
I had the same issue with mine and the new tire didn't hold air at all. I had my brother take it to work and take it off and it was full of crude that the shop didn't clean off, old fix a flat and mystery goo. After the wheel was cleaned and the tire reinstalled it was almost perfect. That was an original i do have a repo as a spear and i noticed it has alot of defects from the casting. I intend to use it as a spear. Most spears I've seen are long and pointy stick thingies. They don't look anything like a Rivvie wheel ............................. The Cap'n might of had one too many of those Becks trying to get in touch with my car German roots. (IMG:style_emoticons/default/beer3.gif) |
gothspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None ![]() |
i had my wheels balanced and they had to put a lot of weights on them.are rivieras known for this? (IMG:style_emoticons/default/lol-2.gif) Nope - at least not with my original Rivs - the later repops may be different, or you may have a bent/tweaked rim, or the tires may the problem. FYI - the "real" Rivs look like this with the smooth outer rim (and interlocking lower case "r" logo on the center caps), whereas the repops have the lip to attach clip-on weights (not advised in any case & they look tacky). ![]() ![]() (IMG:style_emoticons/default/popcorn[1].gif) Freakin awesome!!!! Thanks for the pics!!!! I guess I have REAL Rivieras on my 73' (IMG:style_emoticons/default/smile.gif)!!!!!!!!!!!!!!! |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
The only way to really balance the rivieras, due to the poor quality of the manufacturer, is the mount them on a machine that has the lug centric adapter.
the centers of the Rivs is not always the true center of the circle. Rich |
nsr-jamie |
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None ![]() |
If I were you I would get another set of wheels....maybe some used 4 bolt fuchs or something better quality than what you have now....
Lo-Fi Version | Time is now: 31st July 2025 - 07:43 AM |
