| thezonster |
Oct 20 2010, 09:14 AM
Newbie ![]() Group: Members Posts: 5 Joined: 12-August 10 From: Scottsdale, AZ Member No.: 12,045 Region Association: None |
Its not on the fuse block
| dr914@autoatlanta.com |
Oct 20 2010, 09:30 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,255 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| thezonster |
Oct 20 2010, 07:42 PM
Im not finding it. How would I recognize it if I saw it??
| thezonster |
Oct 21 2010, 06:59 PM
I still need help with this. I did find a relay that is the same as the new turn signal relay that I bought. Is there only one of this type relay in the car?? If so then that must be it. Problem is, that I still have the same problem, after replacing that relay.
| Cap'n Krusty |
Oct 21 2010, 07:10 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Maybe you could tell us what the problem is ......................... I'm guessing it's not that your heater doesn't work ..........................
The Cap'n |
| thezonster |
Oct 22 2010, 08:01 AM
The left and right arrows at the top of the tach. When I turn the left turn signal on, the left arrow flashes, when I turn the right turn signal on, the same left arrow flashes, only very dimly. I was told that this was because the turn signal relay was bad.
| Cap'n Krusty |
Oct 22 2010, 08:24 AM
OK. Did you buy the correct flasher relay? Yours has 4 terminals.
The Cap'n |
| pcar916 |
Oct 22 2010, 08:38 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
The left and right arrows at the top of the tach. When I turn the left turn signal on, the left arrow flashes, when I turn the right turn signal on, the same left arrow flashes, only very dimly. I was told that this was because the turn signal relay was bad. Maybe. But before you replace the relay, make sure all of your bulbs are working and especially that the ground wires are firmly attached. I had a similar problem recently that turned out to be a ground wire that had been pulled loose at the left rear taillight housing. I'd loaded some steel into the rear trunk and wasn't careful enough with it. As for the relay location it's normally under your dash above the fuse panel To find relays and fuses (and every other electrical thing as well) you should always consult the wiring diagrams for wire colors that will tell you what they are. Look at device "47" in this diagram and hunt for those color wires going to a relay under your dash. Good luck! |
| thezonster |
Oct 22 2010, 10:27 AM
Yes its the correct 4 pin relay.
Lo-Fi Version | Time is now: 22nd November 2026 - 02:48 AM |
