1975 electrical help - console connector, Help ID connector |
jpnovak |
Oct 20 2010, 12:54 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I am simplifying the wiring on my 1975 Suby conversion. Under the center console there is a 4 pole connector that I can not ID. The connector is white, round and approximately 12mm OD. It has female plugs. There are a brown, black with Yellow stripe and 4 blue with yellow stripe wires. The 4 B/Y wires are divided over two poles. These go forward under the dash.
This wiring color does not show up in any wiring diagram I have found. Please let me know if you can ID this connector before I cut it out. Thanks. |
JeffBowlsby |
Oct 20 2010, 12:59 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I think thats at the center of the car back by the backpad, not under the center console. Can you post a photo? Your shorthand is 4 B/Y - is that blue/yellow or black/yellow?
Markl |
Oct 20 2010, 01:05 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
Both my '75s have a connector like that hanging down by the steering shaft - neither are connected to anything, and I haven't seen anything that might connect there - I assumed that they are there for A/C, otherwise not needed. Jeff is the wiring expert, maybe he can clarify.
dr914@autoatlanta.com |
Oct 20 2010, 01:13 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
probably for the egr system. Only used in the California cars. Plugs into a counter box to click on the egr light after a certain number of miles
I am simplifying the wiring on my 1975 Suby conversion. Under the center console there is a 4 pole connector that I can not ID. The connector is white, round and approximately 12mm OD. It has female plugs. There are a brown, black with Yellow stripe and 4 blue with yellow stripe wires. The 4 B/Y wires are divided over two poles. These go forward under the dash. This wiring color does not show up in any wiring diagram I have found. Please let me know if you can ID this connector before I cut it out. Thanks. |
jpnovak |
Oct 20 2010, 04:09 PM
jeff, Yes, that is Bl/Y for blue/yellow.
The connector exits the main harness wrap (if you can call spiral tap a wrap) just forward of the shifter mounting hole. I will try to post some pictures tonight. From the sound of things I can leave this alone. |
Lo-Fi Version | Time is now: 10th June 2024 - 04:59 PM |
