> Different Oil Cooling System, Ever seen this?
Cairo94507
post Oct 22 2010, 05:52 PM
Michael
OK, so my car has a 3.0 with Webers. It has what to me appears to be a rather unusual oil cooling system:
Has anyone ever seen something like this? I have a thermostat installed beck near the engine and then this copper pipe running to the front along the passenger side long and looping back to the engine. I guess it worked.
Thanks.
Replies(1 - 10)
Dr Evil
post Oct 22 2010, 08:02 PM
Send me your transmission!
Looks like a facsimile of the trombone cooler used on the early 911s. You could put some cooling fins from a hot water heating system on the pipes and get even more cooling.
Krieger
post Oct 22 2010, 08:13 PM
Looks like Joe the Plumber owned that car! Does it work? Does it leak? If it works on a hot day leave it. Copper is an excellent conductor or heat. Car has a bumper to cover it?
Cairo94507
post Oct 22 2010, 08:55 PM
Michael
According to the PO, it did not overheat, it does not appear any of the copper leaks. Yes; I have a bumper and valance but removed them to swap out the aftermarket air dam for a stock valance and have the under side of the car cleaned.
McMark
post Oct 22 2010, 09:05 PM
914 Freak!
Keep an eye on the rubber/copper transitions and mounting brackets. Vibration can cause problems with copper work hardening and cracking. Otherwise, drive it!
Cairo94507
post Oct 23 2010, 06:21 AM
Michael
Thanks; that is exactly what I plan on doing. Brakes, fuel, oil leaks and then drive. My goal is spring.
carr914
post Oct 23 2010, 06:44 AM
Racer from Birth
If you used a F/G Front Bumper, you could do some custom venting. The Trombone coolers were in a wheel-well, so they got air-flow.
I think the system could work very-well. Is is copper pipe all the way back to the motor?
Mark Henry
post Oct 23 2010, 06:57 PM
that's what I do!
Is it copper or brass? the 90's look heavier than normal.... but it could just be the pic?
Cairo94507
post Oct 23 2010, 07:11 PM
Michael
It is copper all the way back to the engine. I plan to drive it to see how it works.
pete-stevers
post Oct 24 2010, 10:31 AM
Shinee Side Up
looks like it might be an easy change to a coil if need be,
but if those lines are solid you might want to consider flex lines to take the stress off the copper lines at places
copper gets work hardened and can let go
i have copper lines in my car but just up the longs
stownsen914
post Oct 25 2010, 11:06 AM
Is there any rubber hose between the engine and the copper pipe? If not, it is just a matter of time before they break, due to the engine movement relative to the chassis. If there are rubber lines in there somewhere to absorb the movement, then it will probably be OK at least for a while.
Scott
- Lo-Fi Version Time is now: 30th November 2026 - 10:04 AM
