Switch for engine compartment heater fan, Where is it?? |
Van |
Oct 22 2010, 10:04 PM
Member Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 |
I've put an electric blower in the engine compartment (since, for the last 15 years, my car never had it). And, I wired it up per the wiring diagram - relay on the PC board and all... but I don't know where the switch is. It's not the top slider on the dash heater controls - that only operates the fresh air blower.
Can someone point me in the direction of whta *should* switch that fan on and off? Thanks! |
benalishhero |
Oct 22 2010, 10:50 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
IIRC it comes on with the heater box control lever.
Green white. Ground to body according to diagram. |
bmtrnavsky |
Oct 22 2010, 11:02 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
In my car I pull the big red lever by the gear shifter back and the blower in the engine compartment comes on.
The dash levers control the fresh air box in the front trunk. |
oldschool |
Oct 22 2010, 11:20 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) it's on the floor.
McMark |
Oct 22 2010, 11:58 PM
(IMG:style_emoticons/default/agree.gif) The red lever on the center tunnel.
Van |
Oct 23 2010, 07:10 AM
Thanks guys - I had a hunch it was that... Yeah, according to the wiring diagram, it's green with a white stripe. I just glued that tunnel piece of carpet on - but I can pull it off.
Presumably it's a corroded contact or something. |
r_towle |
Oct 23 2010, 07:45 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
its a ground switch...on the floor like they have said.
It opens the flapper valves on the heater tubes via cables, and at the very end of the throw for that lever switch there is a ground contact on the bottom of the lever... It gets really dirty down there...and needs to be cleaned. The idea was that you could open that lever 80% and that opens the flapper boxes all the way...if you open the lever 100% it also turns on the fan... You will find that you dont want that fan on all the time....it will overheat you eventually. Rich |
Cap'n Krusty |
Oct 23 2010, 08:16 AM
Thanks guys - I had a hunch it was that... Yeah, according to the wiring diagram, it's green with a white stripe. I just glued that tunnel piece of carpet on - but I can pull it off. Presumably it's a corroded contact or something. You GLUED the tunnel carpet in place? HA!. What happens when you have to get in there, like this time, when you need to access the shifter, when the clutch cable tube comes adrift, when you need to make sure the cables aren't tangled, when you have to replace the speedo cable? The Cap'n |
underthetire |
Oct 23 2010, 08:21 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Thanks guys - I had a hunch it was that... Yeah, according to the wiring diagram, it's green with a white stripe. I just glued that tunnel piece of carpet on - but I can pull it off. Presumably it's a corroded contact or something. You GLUED the tunnel carpet in place? HA!. What happens when you have to get in there, like this time, when you need to access the shifter, when the clutch cable tube comes adrift, when you need to make sure the cables aren't tangled, when you have to replace the speedo cable? The Cap'n Or stash your pot? (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 11:32 AM |
