Looking for some help, rpms are hanging. |
POScar |
Oct 27 2010, 06:03 PM
Newbie Group: Members Posts: 2 Joined: 25-October 10 From: Jacksonville Member No.: 12,315 Region Association: None |
hey guys first post so take it easy lol. Recently acquired 76 914. I have a dual carburetor setup with the hex bar and i am having problems with the idle and the rpms hanging after stepping on the gas. I don't believe it is a problem with the hex bar or linkages but with the carburetors themselves. i am getting a rhythmic chirping and an jumpy idle. when i engage the clutch to shift the rpms will hang where they were until they are forced to come down from the shifting. I dont know a whole lot about cars let alone carburetors but i believe i have ruled out the hex bar and throttle. Any advice would be appreciated. thanks
jcambo7 |
Oct 27 2010, 08:18 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
hey guys first post so take it easy lol. Recently acquired 76 914. I have a dual carburetor setup with the hex bar and i am having problems with the idle and the rpms hanging after stepping on the gas. I don't believe it is a problem with the hex bar or linkages but with the carburetors themselves. i am getting a rhythmic chirping and an jumpy idle. when i engage the clutch to shift the rpms will hang where they were until they are forced to come down from the shifting. I dont know a whole lot about cars let alone carburetors but i believe i have ruled out the hex bar and throttle. Any advice would be appreciated. thanks Maybe you're float valves in your carbs? Hopefully someone with more experience in carbs can chime in. |
POScar |
Oct 28 2010, 09:48 AM
i took the covers off the carbs and looked down into them everything seems to be sealing well but again i dont know much of what to look for. thanks for the post and yeah i can only hope lol
Tom |
Oct 28 2010, 10:31 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
If you have recently acquired this car, then you really have no idea how the tune is. So, I would see if someone local could give you a hand and adjust the valves, do a good tune up, and synch the carbs. If you still have issues then you may need some carb work. I let the carb gurus explain that as I have fuel injection on mine and don't know these carbs.
Good luck and (IMG:style_emoticons/default/welcome.png) Tom |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:37 AM |
