> Condensor Wire, Mine seems a little short
1988Hawk
post Oct 28 2010, 06:27 AM
I ordered a condensor from PP for a 75 2.0L with FI. The issue I'm having is that once installed the section from the condensor to the distributor entry "plug" is very taunt, to the point where I am worried about damaging the connectivity.
Has anyone esle run into this?
Thanks,
Jim
Replies(1 - 8)
dr914@autoatlanta.com
post Oct 28 2010, 08:28 AM
no should fit fine I am sure that you mounted the condenser under the screw for the vacuum advance. The plugs on the condensers that enter the distributor are too small these days and require some electrical tape to make them fit.
QUOTE(1988Hawk @ Oct 28 2010, 05:27 AM) *
Thanks,
Jim
post Oct 28 2010, 08:29 AM
They didn't waste any wire there, did they? It's close. When the points need to be changed switch over to Petronix solid state (<$70) and eliminate that problem.
Cap'n Krusty
post Oct 28 2010, 08:49 AM
Cap'n Krusty
Or you could simply continue using the original Bosch condenser. I've seen maybe 5-6 condenser failures on VW/Porsche vehicles in 40 years of working on them on a daily basis. BTW, what part number did you use?
The Cap'n
realred914
post Oct 28 2010, 09:03 AM
Group: Retired Members
Install a Pertronix and never mess with points and out of tolerance timing / dwell ever again. thats my advice
1988Hawk
post Oct 28 2010, 10:11 AM
QUOTE(Cap'n Krusty @ Oct 28 2010, 09:49 AM) *
The Cap'n
Cap'n
Part number
Bosch 02054 Distributor Condenser, 1970-76 914-4 1.7L, 2.0L
#311-905-295C-M14
It is about 1/2 inch shorter vs the old one.
Thanks,
Jim
Drums66
post Oct 28 2010, 11:26 AM
914 Rudiments
QUOTE(76-914 @ Oct 28 2010, 07:29 AM) *
...Yeah, teach them a lesson....don't buy anymore?? (IMG:style_emoticons/default/flag.gif)
windforfun
post Oct 28 2010, 12:10 PM
My Bosche condenser wire was so long that I had to coil it up.
Cap'n Krusty
post Oct 28 2010, 12:51 PM
Cap'n Krusty
Where's your coil mounted?
The Cap'n
- Lo-Fi Version Time is now: 8th December 2025 - 11:29 AM
