putting on a new coil.., video update |
ONTHEGRIND |
Nov 3 2010, 12:36 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
anyone have a wiring diagram for hooking up a new coil I pulled mine off a while ago and need to know how tho re hook it up I also have a ignition box to connect best to watch in hd
http://www.youtube.com/watch?v=VNx_VMDB6uM https://www.youtube.com/watch?v=VNx_VMDB6uM |
Mark Henry |
Nov 3 2010, 12:59 PM
The simple is the hot wire goes to + and the condenser (dizzy wire) goes to the -.
If you have a box figure out which on you have and google the wiring diagram. MSD, crane, etc. they are all online. |
ONTHEGRIND |
Nov 3 2010, 01:17 PM
ONTHEGRIND |
Nov 3 2010, 01:23 PM
so I have a red black and purple coming from the box..
Red is positive black is negative Is this correct purple is ground Then I am guessing from the relay box I have red and black twist and a black with some sort on transistor soldered into it im guessing in negative ? |
ONTHEGRIND |
Nov 3 2010, 03:54 PM
bump
ONTHEGRIND |
Nov 4 2010, 02:38 PM
i thought this would be an easy response nobody can confirm what i asked in the video..
benalishhero |
Nov 4 2010, 03:17 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Out of the original harness, the black goes to (+15 on coil) and the black/purple goes to (-1 on coil). The original condensor wire(usually green) should be on -1 too. The black is keyed power and the black/purple goes to the tach.
The double connector(green and brown) powers the heater blower in the engine compartment. I'm not familiar with your allison, but I'm assuming the red is to +15 and the black is to -1 (leave the original black and condensor wire off). Then just put the tach wire back on the -1. Hope this helps...... |
Lo-Fi Version | Time is now: 6th June 2024 - 04:06 AM |
