WTB 19mm sway bar, weltmeister |
tradisrad |
Nov 4 2010, 07:38 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
Edit ad change due to Erics guidance.
WTB weltmeister 22mm front sway bar with arms and drop links. thanks -Rob SF Bay area pick-up would be nice, but I'll spring for shipping. |
Eric_Shea |
Nov 4 2010, 08:25 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
NST (no such thing) - 19mm bars are aftermarket and won't fit stock arms. 18mm turbo bars are one year only and go for around $400+. The stock arms are reinforced for those.
Best to look for a complete used 19mm set-up, either Weltmesiter (most common) or spring for the new GPR version... this way you get adjustable arms that will "really" help your ride quality on the street. Hope that helps. |
tradisrad |
Nov 4 2010, 08:32 AM
NST (no such thing) - 19mm bars are aftermarket and won't fit stock arms. 18mm turbo bars are one year only and go for around $400+. The stock arms are reinforced for those. Best to look for a complete used 19mm set-up, either Weltmesiter (most common) or spring for the new GPR version... this way you get adjustable arms that will "really" help your ride quality on the street. Hope that helps. Thanks Eric, I did see a 19mm bar on the bird board, but the ad was a few months old.. I passed up a good deal on the GPRBar as a friend had a 22mm for me. I probably need to drive the 22mm more, but I'd like to compare them in the car. I'll change my ad. thanks -Rob |
DanT |
Nov 4 2010, 08:48 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Rob,
you may be able to find an old H&H bar in 19mm and they have adjustable arms with about 4 or 5 holes in them that have the same mounting as a stock bar. |
hwgunner |
Nov 4 2010, 10:57 AM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
NST (no such thing) - 19mm bars are aftermarket and won't fit stock arms. 18mm turbo bars are one year only and go for around $400+. The stock arms are reinforced for those. Best to look for a complete used 19mm set-up, either Weltmesiter (most common) or spring for the new GPR version... this way you get adjustable arms that will "really" help your ride quality on the street. Hope that helps. The GPRBar is 19mm (efective, because it is hollow) and fits the stock arms. I sell the bar kit, which includes the bearing blocks and hardware to mount the bar(no arms, drop links), for $225.00 to world members. (IMG:style_emoticons/default/beerchug.gif) |
Eric_Shea |
Nov 4 2010, 08:06 PM
There ya go... Good to know it fits the stock arms. (IMG:style_emoticons/default/wink.gif)
tradisrad |
Nov 5 2010, 07:33 AM
Search is over; wallet is empty.
Next week I'll have a 22mm weltmeister bar, mounts and bushings for sale (no drop links/arms). $120 + ship. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:05 AM |
