It's Porn Time, Engine Porn, that is |
carr914 |
Nov 5 2010, 02:32 PM
Racer from Birth Group: Members Posts: 118,970 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Picked up my 2.8 Twin-Plug today (Thanks smg914 for the help)
67 Aluminum case 2.8 Factory Pistons & Cylinders 2.7 Crank PMO 46 Carbs These are starting to stack up in the garage ( that's a 2.7 Carrera RS motor in the background), I need to start putting these in cars T.C. |
Ferg |
Nov 5 2010, 02:34 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Picked up my 2.8 Twin-Plug today (Thanks smg914 for the help) 67 Aluminum case 2.8 Factory Pistons & Cylinders 2.7 Crank PMO 46 Carbs These are starting to stack up in the garage ( that's a 2.7 Carrera RS motor in the background), I need to start putting these in cars T.C. (IMG:style_emoticons/default/drooley.gif) that would fit nicely in my Carrera, but then it would be facing the wrong direction (IMG:style_emoticons/default/biggrin.gif) |
jt914-6 |
Nov 5 2010, 02:35 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
You got it right TC....THAT goes here.....OTHER goes in the sandbox..... (IMG:style_emoticons/default/biggrin.gif)
00SEVEN |
Nov 5 2010, 02:48 PM
Newbie Group: Members Posts: 17 Joined: 1-November 10 From: Cabot, Arkansas Member No.: 12,343 Region Association: South East States |
I guess i know now where the check I sent you is going.
Sweet looking engine. |
jeffdon |
Nov 5 2010, 03:12 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I would like to offer assistance in clearing out your garage.
mepstein |
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Picking up mine tomorrow. Then it's powdercoat time (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) |
EdwardBlume |
Nov 5 2010, 03:53 PM
(IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/w00t.gif) |
carr914 |
Nov 5 2010, 06:26 PM
I guess i know now where the check I sent you is going. Sweet looking engine. Preston, your check didn't even make a little dent (IMG:style_emoticons/default/biggrin.gif) I'm glad I paid for most of this when the economy was good - this is a Big $$$ motor - over 300HP |
URY914 |
Nov 5 2010, 06:28 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
It belongs inside the house tonight. It's going to be cool here.
carr914 |
Nov 5 2010, 06:47 PM
bcheney |
Nov 5 2010, 07:40 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Nothin wrong with a good block job!!
SirAndy |
Nov 5 2010, 07:54 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Picked up my 2.8 Twin-Plug today Looks like one of the chains is lose ... (IMG:style_emoticons/default/biggrin.gif) |
ArtechnikA |
Nov 6 2010, 06:10 AM
Looks nice!
2.8 Factory Pistons & Cylinders Since the factory 2,8RSR heads have huge combustion chambers and are rare and expensive, how did you manage to keep the CR manageable? Did you find a stash of 2,8 heads, or do some other magick ? For my 2,8 I'm thinking Nickies and JE's just to keep the rest of the custom work to a minimum... |
carr914 |
Nov 6 2010, 06:17 AM
Looks nice! 2.8 Factory Pistons & Cylinders Since the factory 2,8RSR heads have huge combustion chambers and are rare and expensive, how did you manage to keep the CR manageable? Did you find a stash of 2,8 heads, or do some other magick ? For my 2,8 I'm thinking Nickies and JE's just to keep the rest of the custom work to a minimum... Hey Rich, For the heads we used were 2.7 that were ported and Twin-plugged by JB Racing. The CR is 11.5/1 so it will drinking a race gas / non ethanol pump cocktail. |
ChicagoPete |
Nov 6 2010, 08:07 AM
Member Group: Members Posts: 227 Joined: 10-January 05 From: Lake Forest,IL Member No.: 3,427 |
Looks nice! 2.8 Factory Pistons & Cylinders Since the factory 2,8RSR heads have huge combustion chambers and are rare and expensive, how did you manage to keep the CR manageable? Did you find a stash of 2,8 heads, or do some other magick ? For my 2,8 I'm thinking Nickies and JE's just to keep the rest of the custom work to a minimum... Having the same problem when building my engine with factory 92mm p/c and ending up doing alot of work on a set of 2.7L heads to get the compression ratio down to a pump gas level...for a future project I would certainly consider this alternative!! http://www.xtremecylinderheads.com/index.html The are cast heads that can be CNCed to any configuration. I have no idea what the cost for the work on these would be, but, you would get exactly what you are looking for. Peter |
carr914 |
Nov 6 2010, 02:29 PM
carr914 |
Nov 6 2010, 02:31 PM
Bee Jay |
Nov 7 2010, 08:25 AM
Member Group: Members Posts: 204 Joined: 22-April 05 From: Lompoc, Ca. Member No.: 3,964 |
Very nice! Where can I get a single belt engine pulley like that? My 3.0 came with a two belt pulley and it won't fit behind my fiberglass engine tin. I won't be running AC or an airpump and only one alternator belt is needed. I could easily trim the tin but would prefer not to. Bee Jay |
carr914 |
Nov 7 2010, 09:38 AM
I will find where Mike got it ( he might make those). It is bigger than stock ( so the Fan actually turns faster for more cooling), but it will not fit in a Stock 914-6 Cradle Mount without Machining the Cradle
Here is my 2.7 RS with the Stock 2.7 Single Pulley Wheel Gosh I Love Engine Porn (IMG:style_emoticons/default/aktion035.gif) |
sixnotfour |
Nov 7 2010, 09:49 AM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
TC engines look great,
beejay , here is a westcoast supplier; http://rothsport-racing.com/Products/Engin...911-(76-89).htm |
Lo-Fi Version | Time is now: 7th June 2024 - 04:54 AM |
