window adjustment |
window adjustment |
RonnieJ |
Nov 10 2010, 10:36 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
Is there instructions anywhere on how to adjust the windows? My windows seem to be a little off and are not seating into the vertical targa top seals as they should.
tradisrad |
Nov 10 2010, 10:43 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
year model?
dr914@autoatlanta.com |
Nov 10 2010, 11:09 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Yes by all means! Early is harder than the late to adjust. First make sure that the doors fit squarely into the body and that there is no sag. The only adjustment that can be accomplished with the door panel still on is the forward and aft and in and out of the aluminum window divider which in turn tilts the window along with the rear guide. Both are accessible from under the door.
Late 73 after serial number 4732901000 can be adjusted at the rear scissors holder for raising the rear and at the front of the regulator to raise the whole window. The window can be moved front to rear with the large 13mm headed bolt where the regulator attaches to the window at the rectangular white plastic connection The main problem with the early glasses is that the rear and front glued to the window guides loosen and the window either falls or cockeyes. The front of the tube regulator adjusts height but it is hard to get the rear up as the parts wear and the window is virtually suspended by the button on the regulator so the rear is first to sag. Tight guides, good rollers and grease help the problem year model? |
Lo-Fi Version | Time is now: 9th June 2024 - 04:49 PM |
