convert to no bypass filter? |
realred914 |
Nov 14 2010, 11:41 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I have an option of converting my oil filter holder to no -bypass. my engine builder likes that idea, I do to. the probelm will be fitting a high pressure filter to the engine (2056 4 cylinder) what filters are you all using for when the bypass is blocked?
Is there a short version of a high pressure filter as i will be running a sandwhich adaptor to add an oil cooler. I could go with a remote mounted filter also if so, where are some locations of remote filters that you all have used? (photos anyone???) thanks |
McMark |
Nov 14 2010, 01:21 PM
All of the full flow motors I've seen from other builders have used a stock filter.
ME733 |
Nov 14 2010, 02:01 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
There are many full flow, no bypass oil filters available...OBERG...for one., generally if you will research the performance parts distributors they will have several to select from. The bodies of the filter will accomodate "aero-quip", or Earls fittings. You should use at least 200 psi burst pressure lines if remotely locating the filter. This assembly will act as a small oil cooler.
Mark Henry |
Nov 14 2010, 05:24 PM
There are many full flow, no bypass oil filters available...OBERG...for one...... Plugging the oil bypass and full flow are not really the same thing. Full flow is installing the larger type 1 oil pump, drill and tap the galleys, FF cover, hose and a remote mounted filter adapter (or Oberg, System One, etc) If you are just plugging the bypass on the stock console and using a stock T4 pump I see no real advantage for doing this. |
Lo-Fi Version | Time is now: 28th May 2024 - 01:01 PM |
