| pete000 |
Nov 24 2010, 04:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I know this relay was involved in the seat switches, which mine is by passed, but does it run anything else on the car?
Was there a smaller relay next to it? Mine does not seem to have the smaller one. Thanks Attached thumbnail(s) |
| dr914@autoatlanta.com |
Nov 24 2010, 05:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,239 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Nov 24 2010, 05:04 PM
your yellow and yellow with red leads have not been connected together (factory bypass) so you will have to keep your relay plugged in.
I know this relay was involved in the seat switches, which mine is by passed, but does it run anything else on the car? Was there a smaller relay next to it? Mine does not seem to have the smaller one. Thanks |
| jim_hoyland |
Nov 25 2010, 02:20 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,080 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I have one in my '75 and it was bypassed. I'ed like to know how they were wired and worked. Is there anything out there that explains how each of the terminals function ?
| bembry |
Dec 22 2010, 08:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
Per George's reply: What is the interlock? All I had ever heard of was the buzzer.
| mepstein |
Dec 22 2010, 08:34 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,754 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I would like to know how to remove it permanently.
| championgt1 |
Dec 22 2010, 08:35 PM
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,683 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
| bembry |
Dec 22 2010, 08:39 PM
Is there a difference per each model year?
Do all years have the buzzer? The Interlock? |
| championgt1 |
Dec 22 2010, 08:42 PM
Good question. For sure 74 and later. Not sure about earlier cars.
| jt914-6 |
Dec 22 2010, 08:45 PM
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I would like to know how to remove it permanently. Unplug and remove it. Connect the two large yellow wires together. One solid yellow and the other yellow with red stripe. Take a test light and check the smaller wires for 12v with the key on. I have one black wire that hot with the key on. Seal the one (s) that are hot against grounding. As far as I know that system was only used on the '74-76...My '74 had it on it. |
| r_towle |
Dec 22 2010, 09:14 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
| JeffBowlsby |
Dec 22 2010, 09:55 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,264 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
You need the double male connector.
| mepstein |
Dec 22 2010, 10:19 PM
What about all the other (under the seat) wires? I would like to delete as much as I can. Thanks, mark
| r_towle |
Dec 22 2010, 10:23 PM
I had my father (retired EE) reverse engineer this thing a few years back...maybe more than a few.
I posted the diagram here (club/world prior to break) I no longer have the diagram...it may be here. Its all useless stuff... Its all related to the seats pressure sensors, the seatbelt latch sensors, and the door opening light switch/sensor, and all of that starts a buzzer (which needs power) and lights up a light on the dash( which also gets power) the rest of the wires are grounds. Rich |
| Eric_Shea |
Dec 22 2010, 11:54 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I want mine gone to... I'd love to dredge up Rich's thread. It should be here somewhere.
| sixnotfour |
Dec 23 2010, 01:23 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,266 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
From Blowsby, Rich has posts here also;
http://www.914world.com/bbs2/index.php?sho...41066&st=25 Dave Darling; The only power-in on the relay is on the following terminals: 15 (black wire) constant power. L (yellow/red wire) switched power--after it goes through the warning light. C (yellow wire) power when the key is in "start" only. H (grey/yellow wire) switched power, which runs the "door ajar" buzzer (IMG:style_emoticons/default/popcorn[1].gif) Attached thumbnail(s) |
| 914werke |
Dec 23 2010, 11:43 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,679 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Another classic thread resource!
| dflesburg |
Dec 23 2010, 12:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
I agree, re-wire that crap.
| Drums66 |
Dec 23 2010, 12:43 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Per George's reply: What is the interlock? All I had ever heard of was the buzzer. ...All I had ever heard was the buzzer (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/poke.gif) (most people bypass....do what you like?) |
| flipb |
Dec 23 2010, 02:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,877 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
FWIW, My '74 still has the interlock. I think it's kind of charming or something. Although annoying when all you want to do is test something that requires a running engine.
It's a little strange how it works, and it may be due to some loose connections, but here's what I've found: 1. The car won't start unless the driver's belt is buckled. 2. If there's a passenger in the RH seat (pressure sensor), the car won't start unless both belts are buckled. (In my car, this one is sporadic - sometimes works unbuckled) 3. The seat belt latch has to have a pretty solid connection. I've had to unbuckle/rebuckle to get it to work on occasion. 4. This is the one that confuses me - When I have to start the engine a few times in a row, I've tried to buckle the belt without being in the car; just across the seatback. Then I sit down on top of belt so that I can clutch/brake and turn the key... and it doesn't work! Somehow it knows I'm faking and I've had to unbuckle, put the seatbelt on correctly, and buckle before the engine will start. Supposedly, there's some sort of bypass... holding the key to "start" for several seconds, or trying several times in a row... i just can't remember what it is. |
Lo-Fi Version | Time is now: 9th June 2026 - 04:34 PM |
