compufire question |
biker bob |
Nov 27 2010, 10:12 AM
Member Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region |
Since installing a compufire module my plugs are fouling. The spark coming thru the plug is yellow (not blue) and seems to rotate around the electrode before discharging to the tip. Firing from different points on the electrode. Can this be right? Suggestions please.
Cap'n Krusty |
Nov 27 2010, 10:20 AM
Like the points, the replacement units trigger the coil, they don't make the spark stronger or weaker.
The Cap'n |
biker bob |
Nov 27 2010, 12:11 PM
Thanks Cap'n, I have new bosch wires, plugs and blue coil. Does the yellow spark at the plugs indicate a weakness of the coil?
underthetire |
Nov 27 2010, 01:43 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Are you using platinum plugs? I use the compufire and blue coil without problems. Also make sure your coil has full voltage on the + terminal.
orange914 |
Nov 27 2010, 02:25 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Also make sure your coil has full voltage on the + terminal. (IMG:style_emoticons/default/agree.gif) inline resistor? how much? does compufire even run resistance?? |
underthetire |
Nov 27 2010, 02:38 PM
Also make sure your coil has full voltage on the + terminal. (IMG:style_emoticons/default/agree.gif) inline resistor? how much? does compufire even run resistance?? Simple answer, with a bosch blue coil, no. Pretty much same set up as pertronix, with a little better separation between coil trigger points. Simple hook up, just red to coil +, black to coil - (trigger) and the body of it grounded to the distributor and heat sink paste between the module and the mount plate in the dizy. |
biker bob |
Nov 29 2010, 03:05 PM
Drums66 |
Nov 29 2010, 05:02 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
...do the gitty gap again (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 07:26 AM |
