Keyed power source - front trunk |
Scott S |
Nov 29 2010, 03:54 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All,
Is there a keyed power source in the front trunk? Wipers or fresh air blower maybe? I want to relocate my fuel pump. When I pulled the motor, I found that the existing pump was wired to the coil! Very well hidden splice.... I no longer have a relay board, so I am not sure where to grab power. Thanks! Scott S |
McMark |
Nov 29 2010, 04:01 PM
You can connect to the fuse panel. The stock wiring passes through the bulkhead behind the brake fluid reservoir. Very easy to slide another 18g wire through there.
IMHO, a piggyback connection on the fuse panel is acceptable, whereas a random splice from some unassociated component isn't. I'm nitpicky though. |
SirAndy |
Nov 29 2010, 04:18 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The stock fuel-pump uses a 25A fuse AND a relay. Both for a reason ... (IMG:style_emoticons/default/shades.gif)
Get a good relay and use Fuse 11 (un-switched) for the power part of the relay and find a switched connector for the relay trigger. 11 looks to be the main power wire coming from the battery. I'd even add an inline fuse on the power line ... (IMG:style_emoticons/default/popcorn[1].gif) Pic: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-179-1291069128.1.jpg) |
Scott S |
Nov 29 2010, 04:43 PM
That is a better idea for sure Mark - thanks...
Andy, is there a different draw for the fuel injection fuel pump, vs a pump for carbs? Do you think a relay is required on the carb pump? Thanks to you both - (IMG:style_emoticons/default/beerchug.gif) Scott S |
GeorgeRud |
Nov 29 2010, 04:50 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
A relay for a fuel pump is never a bad idea, puts less strain on the switch to that device.
If you're using carbs, it's also a nice little anti-theft device as the car will start, but run out of gas in a few blocks unless the switch is turned on. |
SirAndy |
Nov 29 2010, 05:14 PM
Andy, is there a different draw for the fuel injection fuel pump, vs a pump for carbs? Do you think a relay is required on the carb pump? No idea about the current draw. When i had my carbed 2056, i ran the CB pump off the stock fuel pump wiring. Relay and fuses and all. It sure didn't seem to hurt anything ... (IMG:style_emoticons/default/smile.gif) |
stugray |
Nov 29 2010, 06:51 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am about to relocate the FP for my FI car to the front.
Fuel tank is out and fuel cell on the way, so I will have plenty of room up there since the fuel cell is going where the spare used to be. I plan on running the wire that controls the fuel pump relay through the tunnel with the new fuel lines and relocate the FP relay to the front. SO I will also need a high current wire in the front. I am also considering relocating the battery to the front, but then I have to run big honkin wires to the back for the starter. Anyone else ever done this? Stu |
Hammy |
Nov 30 2010, 12:32 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I am about to relocate the FP for my FI car to the front. Fuel tank is out and fuel cell on the way, so I will have plenty of room up there since the fuel cell is going where the spare used to be. I plan on running the wire that controls the fuel pump relay through the tunnel with the new fuel lines and relocate the FP relay to the front. SO I will also need a high current wire in the front. I am also considering relocating the battery to the front, but then I have to run big honkin wires to the back for the starter. Anyone else ever done this? Stu I don't know if I've ever seen one up front, though somebody probably has. Sometimes they are relocated to the rear trunk if space is an issue in the engine bay. Why do you want to relocate the battery? Assuming your battery tray is structurally good, and you have a good sealed battery (Optima), the stock location is probably best. It's location also helps offset the weight of the driver too. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:15 AM |
