914gt style harness bars, Where to find? |
fasthonda |
Nov 29 2010, 07:29 PM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
Does anyone know where I can get individual harness bars similar what was used in the 914gt or do I need to fab these myself. see photo.
Thanks in Advance. Michael |
McMark |
Nov 30 2010, 12:18 AM
PM Eric_Shea. He's building one of the most accurate GT replicas I've seen.
javadog |
Jan 10 2011, 08:22 AM
Newbie Group: Members Posts: 20 Joined: 3-July 06 From: Tulsa, OK Member No.: 6,358 |
fasthonda |
Jan 10 2011, 11:01 AM
Not willing to spend that much. I ended up making my own from U bolts. Thanks |
PlaysWithCars |
Jan 24 2011, 01:32 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Michael, nice job. They look great. Any pictures of the build process? What u-bolts did you start with? I was planning on doing a similar build but haven't researched starting points yet.
fasthonda |
Jan 24 2011, 06:47 PM
Michael, nice job. They look great. Any pictures of the build process? What u-bolts did you start with? I was planning on doing a similar build but haven't researched starting points yet. Thanks. I am very pleased with how they turned out. HD Galvanized U-Bolts Thread = 3/8 - 16 Dimensions 3 1/16" w X 2 1/2" L This size worked perfectly. For the flanges I started with flange nuts. Drilled out the thread and ground down the top of the nut and welded in place. They would be much prettier if TIG welded. The spacing on the fire wall is important. I spaced them the same width as the harness holes in the back of the race seat, which if I remember right is 20 to 25 cm. Just measure the race seats, this width is pretty standard. I noticed on early GT cars there spacing looks wider than what is ideal for modern race seats. I will add a picture of the backing plates if you want. Regards |
PlaysWithCars |
Jan 27 2011, 09:51 PM
Did you have them plated afterward? They don't look galvanized anymore.
Yeah, a picture of your backing plates would be interesting. Don't go too far out of your way for it though. There's not a lot of room in there so I expect they kind of design themselves based on the available space. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:04 AM |
