WTB:: Rear Coilover setup |
jaybird840 |
Nov 30 2010, 11:03 AM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Hi All,
After my successful (so far!) rebuild and install of my 2.7RS motor, I need to start tuning the suspension to handle the increased weight and HP/Torque. So, I'm in need of a coilover setup for the rear. I'd prefer something that has been set up and run on a six conversion so I don't have to monkey with spring rates too much. My car is a weekend driver, so track spring rates don't apply. Let me know what you've got. Thanks! --jaybird |
hwgunner |
Nov 30 2010, 11:10 AM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
do you have Bilstein rear sport shocks already?
jaybird840 |
Dec 1 2010, 10:36 AM
Koni's, I think.... Lemme check.
hwgunner |
Dec 1 2010, 10:47 AM
Measure the outside diameter of the shock body while you are at it. Some of the Koni's are the correct diameter for the threaded sleeve and some are not. If they are the right diameter then you would not have to buy shocks if yours are still good and you want to keep them. (IMG:style_emoticons/default/beerchug.gif)
DanT |
Dec 1 2010, 11:52 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
or you could just run 180# rear springs...they will be quite capable of handling the 2.7
I had them on my 2.7RS 6 years ago and they worked great on the street and the track...they were mounted on custom valved Bil sports. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:30 PM |
