Looking for Nardi hub for '70-'71 |
grambo |
Dec 6 2010, 07:08 PM
Newbie Group: Members Posts: 8 Joined: 13-February 05 From: Seattle, WA Member No.: 3,594 Region Association: Pacific Northwest |
Anyone have one laying around, or know where they can be purchased? All I can find are the ones for '72-'76.
Also looking for an affordable nardi horn button. Thanks, Graham |
grambo |
Dec 6 2010, 07:10 PM
I suppose an alternative is to use a momo hub and a momo to nardi adapter.
72914S |
Dec 7 2010, 12:10 AM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
What is different from the `72-76 type ? Is it a smaller shaft on the early models ?
MikeSpraggi |
Dec 7 2010, 02:36 AM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
What is different from the `72-76 type ? Is it a smaller shaft on the early models ? I believe the splines or spline count is different on the early models '70-'71 4 cylinders. All original /6 hubs are the same, but are different from the /4s. I was looking around and stumbled across a Volanti Luisi steering wheel hub for a '67- up to '71 VW/914, Part # S5904. I tried it out and finds that it fits my '70 /4. You can search ebay for Volanti Luisi Steering Wheel Hub Adapter for Porsche. Cost is about $70. BTW the hub has wheel patterns for both Momo and Nardi, so there are 12 holes on the wheel side of the hub for the two different sized patterns. Mike |
markb |
Dec 7 2010, 07:24 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I don't think there is a Momo hub available anymore for the 70/71's. If the Volanti Luisi one is still available, jump on it (then let us know (IMG:style_emoticons/default/smile.gif) ).
grambo |
Dec 8 2010, 04:21 PM
Thanks for the tip, Mike. Can the turn signal cancel ring be mounted to the luisi hub?
MikeSpraggi |
Dec 8 2010, 05:05 PM
Thanks for the tip, Mike. Can the turn signal cancel ring be mounted to the luisi hub? I don't have access to mine right now, so I can't take a look. It's with the car at the shop. I can't recall if it does or doesn't. If you give them a call, they should know. They were very helpful when I called them 2 years ago. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:45 AM |
