window glue and lubricant, what to use |
914itis |
Dec 6 2010, 10:38 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
The plastic edge at the bottom of my passenger side window came off. What type of glue should I use to glue it back.. The tracks on either are also pretty dry, should I lubricate them? if so what kind of lubricant to use?
and last, I am putting back my front targa seal, the top one that is attached to the 2 vertical side windows seal. What kind of glue should I use for that? |
McMark |
Dec 6 2010, 10:49 PM
All the seals you mention are installed in 'tracks' and don't need glue. If they won't stay then either the seal is worn out/damaged, or the track is worn out/damaged.
The seals install by pushing the 'lips' in with a screwdriver, they don't slide in. |
IronHillRestorations |
Dec 7 2010, 08:39 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I mark the area where the glue goes, and I gently abrade the glass with a abrasive disc on a die grinder, and use JB Weld.
I doubt if you can get it off the shelf anywhere, but there is a 3M double sided tape that's made for glass, and it really sticks. |
914itis |
Dec 7 2010, 08:58 AM
thanks
dr914@autoatlanta.com |
Dec 7 2010, 09:20 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
window weld urethane for the track to glass and silicone grease to help slide the targa seal down the gutters
The plastic edge at the bottom of my passenger side window came off. What type of glue should I use to glue it back.. The tracks on either are also pretty dry, should I lubricate them? if so what kind of lubricant to use? and last, I am putting back my front targa seal, the top one that is attached to the 2 vertical side windows seal. What kind of glue should I use for that? |
Mikey914 |
Dec 7 2010, 10:23 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
3M weather strip adhesive is handy. It will stay tacky and not harden. It is also much easier to clean off in the future should you ever have to. Although I'm not sure where you would need it here.
Warm soapy water is best for your paint. Take a needle nose pliers and pull it into the channel. If your paint is less than 30 days old do not let silicone anywhere near your paint. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:41 PM |
