How does this come out?, Dash Plate-WTF |
ellisor3 |
Dec 7 2010, 08:02 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I am trying to remove the dash trim plate around the front of the dash to make a template. I have it removed everywhere except arount the cigarette lighter. It looks like there is some type of crush ring behind the lighter. How do you get this off?? I tried pulling it straight out but it will not move.
(IMG:style_emoticons/default/WTF.gif) |
SLITS |
Dec 7 2010, 08:06 AM
You have to keep working the spring washer back and forth till it comes off the barrel of the lighter housing. Small steps ... pain in the ass, but it can be worked off.
Sorry ... no quick solution .... small screwdriver or ? to work the fingers of the washer. |
jaxdream |
Dec 7 2010, 08:40 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Maybe one of those small sets of hook probes available at you FLAPS might give you some purchase on that little devil . I have removed a few of these , and as Slits said -PITA !!! But can be done . Good luck ....
Jack / Jaxdream |
EdwardBlume |
Dec 7 2010, 09:00 AM
Its amazing how much a PITA some of the things are in the 914. You have to be a contortionist to put things together sometimes...
mepstein |
Dec 7 2010, 09:05 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I just took mine out the other day. I wasn't trying to save the trim plate so I held the area on both sides of the lighter and gave it a good tug. It popped right off.
r_towle |
Dec 7 2010, 09:07 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if you have already removed the heater controls, and I mean removed all the way...you can come at it from that hole with a screw driver...a bit easier than laying on your back trying to reach up there and do it.
I have also found that if you grab the back of the lighter and push it out, while rocking it side to side it will move that washer slowly. Its one of those one way washers with teeth that go on, but dont come off. If you manage to apply the right pressure, the teeth flip in the other direction...not all at the same time, but rocking it, twisting it, and pushing all at the same time does the trick. Now that I think about it...I think I used a long screw driver and a hammer to tap the teeth so they loosen up...you end up wrecking the washer a bit, but you can bend it back later once its out of the car. Rich |
realred914 |
Dec 7 2010, 10:25 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
yup one way teeth, so just keep at it, I dont know if new lock rings are available if you can find one, then simply tear it off. else care full rocking and prying will do it, that is how I done mine.
good luck |
Lo-Fi Version | Time is now: 10th June 2024 - 05:35 AM |
