How to Identify Dellorto's, Can I find out the size w/o removing |
Levi |
Apr 23 2004, 07:32 PM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
My 74 2.0 has these duel Dellorto's, who can tell me how to Identify what size they are, I'd like to have kits for them on hand just in case I need them when its time to fire this baby up.
Attached image(s) |
Levi |
Apr 23 2004, 07:33 PM
other one
Attached image(s) |
Levi |
Apr 23 2004, 08:26 PM
Attached image(s) |
skline |
Apr 23 2004, 08:38 PM
It will be stamped on the base of carbs. It should say something like DRLA 40 or DRLA 45 or DRLA 36. I have the 45's and had the 40's before that. They were both the same. Look towards the base of the carbs.
DuckRyder |
Apr 23 2004, 09:56 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Yep should be stamped in the base probably on the "outboard" side. Is that red silicone?
Levi |
Apr 23 2004, 10:19 PM
QUOTE(DuckRyder @ Apr 23 2004, 07:56 PM) Is that red silicone? Good question...I'll have to take a close look at that in the morning... (IMG:style_emoticons/default/unsure.gif) |
DuckRyder |
Apr 23 2004, 10:22 PM
I swear, I fully endorse licensing to buy RTV..............
Levi |
Apr 23 2004, 10:49 PM
I've sure used a ton of the stuff over the years, you can't build a small block Chevy without it....well if you don't want leaks that is (IMG:style_emoticons/default/pray.gif)
914ghost |
Apr 23 2004, 11:39 PM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
Huh? (IMG:style_emoticons/default/huh.gif)
does your throttle cable PUSH on the linkage. ..?Or are the carbs on inside out? Seem's like a 'pull' from your throttle cable shuts the carbs....or they're on lefthanded?! (IMG:style_emoticons/default/wacko.gif) It's one of those "magic eye" things eh? I'll see the answer if I stare long enough. -Bob O p.s. Get you rebuild kits now!!! They're seeming to be hard to find (at a normal price). |
lapuwali |
Apr 23 2004, 11:59 PM
The throttle arms are on the inside, so it pulls them up to open.
Funny, when I put my Webers on, I thought I was doing something really cheesy running a big return spring from the center arm back to the trunk spring. Now I see nearly everyone does the same thing.... |
Lo-Fi Version | Time is now: 8th June 2024 - 04:17 AM |
