My winter project ... |
SirAndy |
Dec 7 2010, 10:55 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hopefully, this thread will help me keep track of all the things i want to do to the car this winter. (IMG:style_emoticons/default/screwy.gif)
Consider this my public notebook ... (IMG:style_emoticons/default/biggrin.gif) Parts needed (Parts i already have are marked with [X]): ---------------------------------------------------------------------------------- [ ] - Fiberglass GT front bumper (Getty ?) [ ] - Fiberglass GT lower valance (Getty ?) [ ] - Fiberglass GT rocker panels (Getty ?) [X] - Fiberglass rear 916 bumper. [ ] - Front oil cooler ducting. [X] - Fiberglass flares, extra wide, 9" front and 11" rear [X] - New wheels and tires. Fikse FM10's, 9x17 with 245-45 and 11x17 with 315-35 (Hoosier Dot R's). [ ] - Boxster brake calipers front/rear. [ ] - Boxster brake caliper adapters. [ ] - Front brake ducts and shields. [ ] - Second Sparco Evo-L seat for the passenger. [ ] - Evo-L mounting brackets. [X] - Front belly pan. [X] - Rear removable trunk floor. [ ] - Additional tubing to brace the front and rear shock towers. [ ] - Additional tubing to brace the rear lower suspension mounts. [X] - Front FreeMotion roller bearings. [X] - GT style door pulls. [ ] - New battery. [ ] - New fuel filter. [ ] - New oil filter. [ ] - New set of side mirrors. (Brand???) [X] - JWest fuse panel. [X] - Camp914 fog lights. [X] - 100W head lights. [X] - JWest fog-light flasher setup. [ ] - Stronger clutch setup. (Stage III ???) [X] - Front Euro turn signals. [ ] - Rear Euro lenses. [ ] - Sound deadening material. [ ] - Roll bar padding. [X] - New carpet kit. [ ] - Wide angle, roll bar mounted rear view mirror. [ ] - Correct oil pressure sender. [X] - Old style 911 combi-instrument. Work needed: ---------------------------------------------------------------------------------- [ ] - Remove current FG flares, bumpers and rockers. [ ] - Add new flares. [ ] - Add/modify new rockers. [ ] - Add/modify new bumpers and valances. [ ] - Replace rear decklid and remove spoiler from the old one.[ ] [ ] - Add Boxster brakes and adapters. [ ] - Add bracing to the shock towers and suspension mounts. [ ] - Fix oil line leak. [ ] - Change oil. [ ] - Change remaining two spark plugs. [ ] - Add custom seat braces and mount racing seats. [ ] - Mount 5-point harness. Add harness loops to the rollcage. [ ] - Replace vertical rollcage tube on the pass. side with a bend one for more room. [ ] - Re-weld rollcage joints. [ ] - Seam-weld (parts) of the chassis. [ ] - Repair long damage from the celette pulling. [ ] - Replace top with early style. (New seals?) [ ] - Rebuild steering rack. [ ] - Replace steering rack rubber donut with solid one (If needed?) [ ] - Add GT style door pulls. [ ] - Redo fuel pump box and mounting. (Go with larger supply lines?) (Use the high flow pump?) [ ] - Fix fresh air blower. [ ] - Clean up the wire mess for the 3.6L brain. [ ] - Fix fuel line routing in the engine comp. [ ] - Fix drivers door latch. [ ] - Cap off heater ducts in the engine comp. [ ] - Add JWest fuse panel. [ ] - Install upgraded fuse block. [ ] - Install new headlights and foglights. [ ] - Add mount for front license plate. [ ] - Install new side mirrors. [ ] - Fix throttle cable routing on engine. [ ] - Add front euro turn signals. [ ] - Add rear euro lenses. [ ] - Touch up paint where needed. [ ] - Add sound deadening. [ ] - Redo roll bar padding. [ ] - Install carpet kit. [ ] - Install new rear view mirror. [ ] - Redo "916 targa" badge. [ ] - Fix GT engine lid. [ ] - Add rain shield for engine air intake. [ ] - Black out engine cover side-vents. [ ] - Add/fix charcoal canister and tank venting. [ ] - Fix tank filler seal leak. [ ] - Add padding to front swaybar. [ ] - Corner balance and align the car. [ ] - Powdercoat remaining suspension pieces. [ ] - Add front air-diverter (Removable, under the valance). I'm sure i missed a few things, i'll update this list as i go along ... (IMG:style_emoticons/default/santa_smiley.gif) ... |
SirAndy |
Dec 7 2010, 10:56 PM
DanT |
Dec 7 2010, 11:02 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
wow that is an ambitious list Andy....but sounds like the car will look and perform (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) fantastic when you are done. (IMG:style_emoticons/default/biggrin.gif)
Andyrew |
Dec 7 2010, 11:20 PM
At least it drives... Or did you decide your doing this to the 6 tub?
SirAndy |
Dec 7 2010, 11:21 PM
At least it drives... Or did you decide your doing this to the 6 tub? Naaa, that's the red car. But maybe now you can see my point why i've been thinking about building up the /6 instead. Just as much work if you want to do it right ... (IMG:style_emoticons/default/dry.gif) |
oldschool |
Dec 7 2010, 11:36 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
Andy we in ca.....we don't have winters (IMG:style_emoticons/default/av-943.gif)
Lennies914 |
Dec 8 2010, 12:30 AM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
(IMG:style_emoticons/default/popcorn[1].gif) .............and finish the limo? (IMG:style_emoticons/default/pray.gif)
Andyrew |
Dec 8 2010, 10:31 AM
Remember Andy, I was one of the guys saying to hack up that 6 chassis... My argument was that properly modified 6's are worth more than properly modified 4's... Maybe as much as you were going to sell the chassis for.
However now you have to buy all the parts you were going to reuse on the red car.. And probably put a cage. So you've got 15k in parts you have to buy now... But at least you'd have 2 cars (unless you sold one...) |
r_towle |
Dec 8 2010, 10:39 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Given your plans, do it to the six tub instead.
Get a cage in there and the tub will look more appealing once you know its solid. You have are replacing bodywork in your plan anyways... Do it to the tub The nice part is that you can drive your car while you work on the tub. I suspect someone will buy your red car in the spring if you can find another motor for the tub. Think of how nice a fresh new wiring harness will be...now THAT is a winter/kitchen table project that I KNOW you loved the first time. Rich |
dr914@autoatlanta.com |
Dec 8 2010, 10:44 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Sir, if you would consider us I would like to donate some things on your list.
Hopefully, this thread will help me keep track of all the things i want to do to the car this winter. (IMG:style_emoticons/default/screwy.gif) Consider this my public notebook ... (IMG:style_emoticons/default/biggrin.gif) Parts needed (Parts i already have are marked with [X]): ---------------------------------------------------------------------------------- [ ] - Fiberglass GT front bumper (Getty ?) [ ] - Fiberglass GT lower valance (Getty ?) [ ] - Fiberglass GT rocker panels (Getty ?) [X] - Fiberglass rear 916 bumper. [ ] - Front oil cooler ducting. [X] - Fiberglass flares, extra wide, 9" front and 11" rear [X] - New wheels and tires. Fikse FM10's, 9x17 with 245-45 and 11x17 with 315-35 (Hoosier Dot R's). [ ] - Boxster brake calipers front/rear. [ ] - Boxster brake caliper adapters. [ ] - Front brake ducts and shields. [ ] - Second Sparco Evo-L seat for the passenger. [ ] - Evo-L mounting brackets. [X] - Front belly pan. [X] - Rear removable trunk floor. [ ] - Additional tubing to brace the front and rear shock towers. [ ] - Additional tubing to brace the rear lower suspension mounts. [X] - Front FreeMotion roller bearings. [X] - GT style door pulls. [ ] - New battery. [ ] - New fuel filter. [ ] - New oil filter. [ ] - New set of side mirrors. (Brand???) [X] - JWest fuse panel. [X] - Camp914 fog lights. [X] - 100W head lights. [X] - JWest fog-light flasher setup. [ ] - Stronger clutch setup. (Stage III ???) [X] - Front Euro turn signals. [ ] - Rear Euro lenses. [ ] - Sound deadening material. [ ] - Roll bar padding. [X] - New carpet kit. [ ] - Wide angle, roll bar mounted rear view mirror. [ ] - Correct oil pressure sender. [X] - Old style 911 combi-instrument. Work needed: ---------------------------------------------------------------------------------- [ ] - Remove current FG flares, bumpers and rockers. [ ] - Add new flares. [ ] - Add/modify new rockers. [ ] - Add/modify new bumpers and valances. [ ] - Replace rear decklid and remove spoiler from the old one.[ ] [ ] - Add Boxster brakes and adapters. [ ] - Add bracing to the shock towers and suspension mounts. [ ] - Fix oil line leak. [ ] - Change oil. [ ] - Change remaining two spark plugs. [ ] - Add custom seat braces and mount racing seats. [ ] - Mount 5-point harness. Add harness loops to the rollcage. [ ] - Replace vertical rollcage tube on the pass. side with a bend one for more room. [ ] - Re-weld rollcage joints. [ ] - Seam-weld (parts) of the chassis. [ ] - Repair long damage from the celette pulling. [ ] - Replace top with early style. (New seals?) [ ] - Rebuild steering rack. [ ] - Replace steering rack rubber donut with solid one (If needed?) [ ] - Add GT style door pulls. [ ] - Redo fuel pump box and mounting. (Go with larger supply lines?) (Use the high flow pump?) [ ] - Fix fresh air blower. [ ] - Clean up the wire mess for the 3.6L brain. [ ] - Fix fuel line routing in the engine comp. [ ] - Fix drivers door latch. [ ] - Cap off heater ducts in the engine comp. [ ] - Add JWest fuse panel. [ ] - Install upgraded fuse block. [ ] - Install new headlights and foglights. [ ] - Add mount for front license plate. [ ] - Install new side mirrors. [ ] - Fix throttle cable routing on engine. [ ] - Add front euro turn signals. [ ] - Add rear euro lenses. [ ] - Touch up paint where needed. [ ] - Add sound deadening. [ ] - Redo roll bar padding. [ ] - Install carpet kit. [ ] - Install new rear view mirror. [ ] - Redo "916 targa" badge. [ ] - Fix GT engine lid. [ ] - Add rain shield for engine air intake. [ ] - Black out engine cover side-vents. [ ] - Add/fix charcoal canister and tank venting. [ ] - Fix tank filler seal leak. [ ] - Add padding to front swaybar. [ ] - Corner balance and align the car. [ ] - Powdercoat remaining suspension pieces. [ ] - Add front air-diverter (Removable, under the valance). I'm sure i missed a few things, i'll update this list as i go along ... (IMG:style_emoticons/default/santa_smiley.gif) ... |
Tom_T |
Dec 8 2010, 11:40 AM
Andy, I while back I saw somebody selling some new FG GT bumpers/spoiler/valance on TheSamba, but don't recall when/where nor quality. I'd also seen someone selling a F&R decklids & F&R GT bumpers in CF there too. May be worth perusing their ads back to front?
markb |
Dec 8 2010, 01:19 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Given your plans, do it to the six tub instead. Get a cage in there and the tub will look more appealing once you know its solid. You have are replacing bodywork in your plan anyways... Do it to the tub The nice part is that you can drive your car while you work on the tub. I suspect someone will buy your red car in the spring if you can find another motor for the tub. Think of how nice a fresh new wiring harness will be...now THAT is a winter/kitchen table project that I KNOW you loved the first time. Rich (IMG:style_emoticons/default/agree.gif) This makes the most amount of sense. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:18 AM |
