Hopefully, this thread will help me keep track of all the things i want to do to the car this winter.
Consider this my public notebook ...
Parts needed (Parts i already have are marked with [X]):
[ ] - Fiberglass GT front bumper (Getty ?)
[ ] - Fiberglass GT lower valance (Getty ?)
[ ] - Fiberglass GT rocker panels (Getty ?)
[X] - Fiberglass rear 916 bumper.
[ ] - Front oil cooler ducting.
[X] - Fiberglass flares, extra wide, 9" front and 11" rear
[X] - New wheels and tires. Fikse FM10's, 9x17 with 245-45 and 11x17 with 315-35 (Hoosier Dot R's).
[ ] - Boxster brake calipers front/rear.
[ ] - Boxster brake caliper adapters.
[ ] - Front brake ducts and shields.
[ ] - Second Sparco Evo-L seat for the passenger.
[ ] - Evo-L mounting brackets.
[X] - Front belly pan.
[X] - Rear removable trunk floor.
[ ] - Additional tubing to brace the front and rear shock towers.
[ ] - Additional tubing to brace the rear lower suspension mounts.
[X] - Front FreeMotion roller bearings.
[X] - GT style door pulls.
[ ] - New battery.
[ ] - New fuel filter.
[ ] - New oil filter.
[ ] - New set of side mirrors. (Brand???)
[X] - JWest fuse panel.
[X] - Camp914 fog lights.
[X] - 100W head lights.
[X] - JWest fog-light flasher setup.
[ ] - Stronger clutch setup. (Stage III ???)
[X] - Front Euro turn signals.
[ ] - Rear Euro lenses.
[ ] - Sound deadening material.
[ ] - Roll bar padding.
[X] - New carpet kit.
[ ] - Wide angle, roll bar mounted rear view mirror.
[ ] - Correct oil pressure sender.
[X] - Old style 911 combi-instrument.
Work needed:
[ ] - Remove current FG flares, bumpers and rockers.
[ ] - Add new flares.
[ ] - Add/modify new rockers.
[ ] - Add/modify new bumpers and valances.
[ ] - Replace rear decklid and remove spoiler from the old one.[ ]
[ ] - Add Boxster brakes and adapters.
[ ] - Add bracing to the shock towers and suspension mounts.
[ ] - Fix oil line leak.
[ ] - Change oil.
[ ] - Change remaining two spark plugs.
[ ] - Add custom seat braces and mount racing seats.
[ ] - Mount 5-point harness. Add harness loops to the rollcage.
[ ] - Replace vertical rollcage tube on the pass. side with a bend one for more room.
[ ] - Re-weld rollcage joints.
[ ] - Seam-weld (parts) of the chassis.
[ ] - Repair long damage from the celette pulling.
[ ] - Replace top with early style. (New seals?)
[ ] - Rebuild steering rack.
[ ] - Replace steering rack rubber donut with solid one (If needed?)
[ ] - Add GT style door pulls.
[ ] - Redo fuel pump box and mounting. (Go with larger supply lines?) (Use the high flow pump?)
[ ] - Fix fresh air blower.
[ ] - Clean up the wire mess for the 3.6L brain.
[ ] - Fix fuel line routing in the engine comp.
[ ] - Fix drivers door latch.
[ ] - Cap off heater ducts in the engine comp.
[ ] - Add JWest fuse panel.
[ ] - Install upgraded fuse block.
[ ] - Install new headlights and foglights.
[ ] - Add mount for front license plate.
[ ] - Install new side mirrors.
[ ] - Fix throttle cable routing on engine.
[ ] - Add front euro turn signals.
[ ] - Add rear euro lenses.
[ ] - Touch up paint where needed.
[ ] - Add sound deadening.
[ ] - Redo roll bar padding.
[ ] - Install carpet kit.
[ ] - Install new rear view mirror.
[ ] - Redo "916 targa" badge.
[ ] - Fix GT engine lid.
[ ] - Add rain shield for engine air intake.
[ ] - Black out engine cover side-vents.
[ ] - Add/fix charcoal canister and tank venting.
[ ] - Fix tank filler seal leak.
[ ] - Add padding to front swaybar.
[ ] - Corner balance and align the car.
[ ] - Powdercoat remaining suspension pieces.
[ ] - Add front air-diverter (Removable, under the valance).
I'm sure i missed a few things, i'll update this list as i go along ...
